To make a new file system on a disk slice, you almost always use the newfs command. The following table shows the default parameters that are used by the newfs command.
Parameter |
Default Value |
Block size |
8 Kbytes |
Fragment size |
1 Kbyte |
Minimum free space |
((64 Mbytes/partition size) * 100), rounded down to the nearest integer and limited to between 1% and 10%, inclusively |
Rotational delay |
Zero |
Optimization type |
Time |
Number of inodes |
1 inode for each 2 Kbytes of data space |
