After you create a file system, you need to make it available to the system so you can use it. You make a file system available by mounting it, which attaches the file system to the system directory tree at the specified mount point. The root (/) file system is always mounted.
The following table provides guidelines on mounting file systems based on how you use them.
You can mount media that contains a file system by inserting the media into the drive and running the volcheck command if necessary. For more information on mounting removable media, see Chapter 1, Managing Removable Media (Overview).
The following table lists the commands in the /usr/sbin directory that you use to mount and unmount file systems.
Table 17–1 Commands for Mounting and Unmounting File Systems
Command |
Man Page |
Description |
mount |
Mounts file systems and remote resources. |
mountall |
Mounts all file systems that are specified in the /etc/vfstab file. The mountall command runs automatically when the system enters multiuser mode. |
umount |
Unmounts file systems and remote resources. |
umountall |
Unmounts all file systems that are specified in the /etc/vfstab file. |
The mount and mountall commands will not mount a read/write file system that has known inconsistencies. If you receive an error message from the mount or mountall command, you might need to check the file system. See Chapter 20, Checking UFS File System Consistency (Tasks) for information on how to check the file system.
The umount and umountall commands will not unmount a file system that is busy. A file system is considered busy if one of the following is true:
A user is accessing a file or directory in the file system.
If a program has a file open in that file system.
If the file system is shared.
The following table describes the commonly used options that you can specify with the mount -o option. If you specify multiple options, separate them with commas (no spaces). For example, -o ro,nosuid.
For a complete list of mount options for each file system type, refer to the specific mount man pages (for example, mount_ufs(1M)).
Table 17–2 Commonly Used -o Mount Options
Option |
File System |
Description |
bg | fg |
NFS |
If the first mount attempt fails, retries in the background (bg) or in the foreground (fg). This option is safe for non-critical vfstab entries. The default is fg. |
hard | soft |
NFS |
Specifies the procedure if the server does not respond. The soft option indicates that an error is returned. The hard option indicates that the retry request is continued until the server responds. The default is hard. |
intr | nointr |
NFS |
Specifies whether keyboard interrupts are delivered to a process that is hung while waiting for a response on a hard-mounted file system. The default is intr (interrupts allowed). |
largefiles | nolargefiles |
UFS |
Enables you to create files larger than 2 Gbytes. The largefiles option means that a file system mounted with this option might contain files larger than 2 Gbytes, but it is not required. If the nolargefiles option is specified, the file system cannot be mounted on a system that is running Solaris 2.6 or compatible versions. The default is largefiles. |
logging | nologging |
UFS |
Enables or disables logging for the file system. UFS logging is the process of storing transactions (changes that make up a complete UFS operation) into a log before the transactions are applied to the UFS file system. Logging helps prevent UFS file systems from becoming inconsistent, which means fsck can be bypassed. Bypassing fsck reduces the time to reboot a system if it crashes, or after a system is shutdown uncleanly. The log is allocated from free blocks on the file system, and is sized at approximately 1 Mbyte per 1 Gbyte of file system, up to a maximum of 64 Mbytes. The default is logging. |
atime | noatime |
UFS |
Suppresses access time updates on files, except when they coincide with updates to the time of the last file status change or the time of the last file modification. For more information, see stat(2). This option reduces disk activity on file systems where access times are unimportant (for example, a Usenet news spool). The default is normal access time (atime) recording. |
remount |
All |
Changes the mount options associated with an already-mounted file system. This option can generally be used with any option except ro, but what can be changed with this option is dependent on the file system type. |
retry=n |
NFS |
Retries the mount operation when it fails. n is the number of times to retry. |
ro | rw |
CacheFS, NFS, PCFS, UFS, HSFS |
Specifies read/write (rw) or read-only (ro). If you do not specify this option, the default is rw. The default option for HSFS is ro. |
suid | nosuid |
CacheFS, HSFS, NFS, UFS |
Allows or disallows setuid execution. The default is to allow setuid execution. |
An entry in the /etc/vfstab file has seven fields, which are described in the following table.
Table 17–3 Field Descriptions for the /etc/vfstab File
Field Name |
Description |
device to mount |
This field identifies one of the following:
device to fsck |
The raw (character) device name that corresponds to the UFS file system identified by the device to mount field (for example, /dev/rdsk/c0t0d0s0). This field determines the raw interface that is used by the fsck command. Use a dash (-) when there is no applicable device, such as for a read-only file system or a remote file system. |
mount point |
Identifies where to mount the file system (for example, /usr).
FS type |
Identifies the type of file system. |
fsck pass |
The pass number used by the fsck command to decide whether to check a file system. When the field contains a dash (-), the file system is not checked. When the field contains a zero, UFS file systems are not checked but non-UFS file systems are checked. When the field contains a value greater than zero, the file system is always checked. All file systems with a value of 1 in this field are checked one at a time in the order they appear in the vfstab file. When the fsck command is run on multiple UFS file systems that have fsck pass values greater than one and the preen option (-o p) is used, the fsck command automatically checks the file systems on different disks in parallel to maximize efficiency. Otherwise, the value of the pass number does not have any effect. |
mount at boot |
Set to yes or no for whether the file system should be automatically mounted by the mountall command when the system is booted. Note that this field has nothing to do with AutoFS. The root (/), /usr and /var file systems are not mounted from the vfstab file initially. This field should always be set to no for these file systems and for virtual file systems such as /proc and /dev/fd. |
mount options |
A list of comma-separated options (with no spaces) that are used for mounting the file system. Use a dash (-) to indicate no options. For a list of commonly used mount options, see Table 17–2. |
You must have an entry in each field in the /etc/vfstab file. If there is no value for the field, be sure to enter a dash (-). Otherwise, the system might not boot successfully. Similarly, white space should not be used in a field value.
