System Administration Guide: Devices and File Systems
ProcedureHow to Mount an NFS File System (mount Command)
Steps
  1. Become superuser or assume an equivalent role.
  2. Create a mount point for the file system to be mounted, if necessary.
    # mkdir /mount-point
    There must be a mount point on the local system to mount a file system. A mount point is a directory to which the mounted file system is attached.
  3. Make sure the resource (file or directory) is available from a server.
    To mount an NFS file system, the resource must be made available on the server by using the share command. For information on how to share resources, see About the NFS Service in System Administration Guide: Resource Management and Network Services.
  4. Mount the NFS file system.
    # mount -F nfs [-o mount-options] server:/directory /mount-point
    -o mount-options
    Specifies mount options that you can use to mount an NFS file system. See Table 17–2 for the list of commonly used mount options or mount_nfs(1M) for a complete list of options.
    server:/directory
    Specifies the server's host name that contains the shared resource, and the path to the file or directory to mount.
    /mount-point
    Specifies the directory on which to mount the file system.
Example 17–7 Mounting an NFS File System (mount Command)
The following example shows how to mount the /export/packages directory on /mnt from the server pluto.
# mount -F nfs pluto:/export/packages /mnt
