System Administration Guide: Devices and File Systems
Overview of File Systems
A file system is a structure of directories that is used to organize and store files. The term file system is used to describe the following:
Usually, you can tell from the context which meaning is intended.
The Solaris operating system uses the virtual file system (VFS) architecture, which provides a standard interface for different file system types. The VFS architecture enables the kernel to handle basic operations, such as reading, writing, and listing files, and makes it easier to add new file systems.
