The /usr/sbin/swap command is used to manage swap areas. Two options, -l and -s, display information about swap resources.
Use the swap -l command to identify a system's swap areas. Activated swap devices or files are listed under the swapfile column.
# swap -l swapfile dev swaplo blocks free /dev/dsk/c0t0d0s1 136,1 16 1638608 1600528 |
Use the swap -s command to monitor swap resources.
# swap -s total: 57416k bytes allocated + 10480k reserved = 67896k used, 833128k available |
The used value plus the available value equals the total swap space on the system, which includes a portion of physical memory and swap devices (or files).
You can use the amount of available and used swap space (in the swap -s output) as a way to monitor swap space usage over time. If a system's performance is good, use swap -s to see how much swap space is available. When the performance of a system slows down, check the amount of available swap space to see if it has decreased. Then you can identify what changes to the system might have caused swap space usage to increase.
When using this command, keep in mind that the amount of physical memory available for swap usage changes dynamically as the kernel and user processes lock down and release physical memory.
The swap -l command displays swap space in 512-byte blocks and the swap -s command displays swap space in 1024-byte blocks. If you add up the blocks from swap -l and convert them to Kbytes, the result will be less than used + available (in the swap -s output) because swap -l does not include physical memory in its calculation of swap space.
The output from the swap -s command is summarized in the following table.
Table 19–1 Output of the swap -s Command
Keyword |
Description |
bytes allocated |
The total amount of swap space in 1024-byte blocks that is currently allocated as backing store (disk-backed swap space). |
reserved |
The total amount of swap space in 1024-byte blocks that is not currently allocated, but claimed by memory for possible future use. |
used |
The total amount of swap space in 1024-byte blocks that is either allocated or reserved. |
available |
The total amount of swap space in 1024-byte blocks that is currently available for future reservation and allocation. |
