System Administration Guide: Devices and File Systems
ProcedureHow to Play a Musical CD or DVD
To play musical media from a media drive attached to a system running the Solaris release, you'll need to access public domain software, such as xmcd, that is available from the following locations:
Keep the following in mind when using the xmcd software with CDDA (CD Digital Audio) support to play musical media:
Consider the following issues as well:
Once you install the xmcd software, you can play a musical CD simply by inserting it into the CD-ROM drive and starting the xmcd control panel.
Steps
  1. Install the xmcd software.
  2. Insert the media into the media drive.
  3. Invoke the xmcd command.
    % ./xmcd &
