The cdrw command works with or without vold running. However, you must have superuser or role access to stop and start the vold daemon.
Insert a CD into the CD-RW device.
The CD can be any CD that the device can read.
Check that the CD-RW drive is connected properly by listing the device.
$ cdrw -l
Looking for CD devices...
Node Connected Device Device type
cdrom1 | YAMAHA CRW8424S 1.0d | CD Reader/Writer
(Optional) If you do not see the drive in the list, you might have to do a reconfiguration boot so that the system recognizes the device.
# touch /reconfigure # init 6 |
Or, use the following commands to add the CD-RW device without rebooting the system.
# drvconfig # disks |
Then restart vold.
# /etc/init.d/vold stop # /etc/init.d/vold start |
