The following features are no longer supported in the Solaris 9 software.
The adb utility is implemented as a link to the new mdb utility in this release.
The mdb(1) man page describes the features of the new debugger, including its adb compatibility mode. Even in this compatibility mode, differences between adb(1) and mdb exist. The following are some examples of these differences:
The text output format of some subcommands is different in mdb. Macro files are formatted by using the same rules, but scripts that depend on the output of other subcommands might need to be modified.
The watchpoint-length specifier syntax in mdb is different from the syntax that is described in adb. The adb watchpoint commands :w, :a, and :p enable an integer length (in bytes) to be inserted between the colon and the command character. In the mdb(1) man page, the count should be specified after the initial address as a repeat count.
The adb command 123:456w is specified in the mdb man page as 123,456:w.
The /m, /*m, ?m, and ?*m format specifiers are not recognized or supported by mdb.
The AnswerBook2TM server is no longer included in this release. Existing AnswerBook2 servers can run on the Solaris 9 software. Solaris documentation is available on the Solaris Documentation CD in online formats. All Solaris documentation is also always available at http://docs.sun.com.
The aspppd utility is no longer included in this release. Instead, use the pppd(1M) utility with Solaris PPP 4.0 utility that is included in the Solaris 9 software.
The ATOK8 Japanese input method is no longer supported in this release. The ATOK12 Japanese input method is included in the Solaris 9 software. The ATOK12 Japanese input method provides functionality that is similar to the ATOK8, with the addition of several enhancements.
The crash utility is no longer supported in this release. In the Solaris 9 software, the mdb(1) utility provides a function that is similar to the crash utility. The mdb utility also examines system crash dump files. The crash utility's interface has been structured around implementation details, such as slots, that have no relation to the Solaris software implementation.
The Solaris Modular Debugger Guide provides information for users who are making the transition from using crash to using mdb.
The capability of applying the ipcs(1) command to system crash dumps by using the -C and -N command-line options is no longer supported in this release. Equivalent capability is now provided by the mdb(1) ::ipcs debugger command.
The cs00 Japanese input method is no longer supported in the Solaris 9 software. Related interfaces, such as the xci interface, the Japanese Feature Package (JFP) libmle API, and the mle command, are also no longer supported in the Solaris 9 software.
If you upgrade to the Solaris 9 software from a previous release, the existing public user dictionary /var/mle/ja/cs00/cs00_u.dic is removed.
Two Japanese input methods, ATOK12 and Wnn6, are supported in the Solaris 9 software. For more information on the ATOK12 and Wnn6 input methods, see the International Language Environments Guide.
The devconfig command is no longer supported in this release.
The following table lists devices and driver software that are no longer supported in this release.
Table 3–1 Devices and Driver Software
Name of Physical Device |
Name of Driver |
Type of Card |
Melds/Buslogic FlashPoint Ultra PCI SCSI |
flashpt |
SCSI HBA |
Madge Token Ring Smart 16/4, Madge Token Ring Smart 16/4 PCI BM Mk2, Madge Token Ring Smart 16/4 PCI BM Mk1, and Madge Token Ring PCI Presto |
mtok |
Network |
Compaq Integrated NetFlex-3 10/100 T PCI, Compaq NetFlex-3/P, Compaq NetFlex-3 DualPort 10/100 TX PCI, Compaq Netelligent 10 T PCI, and Compaq Netelligent 10/100 TX PCI |
cnft |
Network |
The name of the EA directory has been changed to ExtraValue in the Solaris 9 software.
The MD21 disk controller for ESDI drives is no longer supported in the Solaris 9 software.
The enable_mixed_bcp tunable is no longer supported in this release. In Solaris releases prior to the Solaris 9 release, the /etc/system variable enable_mixed_bcp could be set to 0 to disable dynamic linking of partially statically linked SunOSTM 4.0 and compatible executables. The system used dynamic linking for these executables by default. In the Solaris 9 software, dynamic linking is always used for these executables, and the enable_mixed_bcp tunable has been removed from the system. This change does not affect binary compatibility for SunOS 4.0 and compatible executables in any way.
The Solaris software is no longer supported on Intel 486–based systems.
The japanese locale name alternate of the ja Japanese Extended UNIX Code (EUC) locale is no longer supported in this release. This locale name facilitated migration from the Solaris 1.0 release and compatible releases. You can use ja or ja_JP.eucJP as the Japanese EUC locale with the Solaris 9 software. The Solaris 1.0 BCP (JLE) application and compatible versions can still run in the Solaris 9 software without any changes.
Version 1.2.2 of the Java SDK (SUNWj2dev) is no longer included in the Solaris 9 software. Near-equivalent capability is supported by Java 2 Standard Edition, versions 1.4 and compatible versions. Current and previous versions of JDK and Java runtime environment (JRE) are available for download from http://java.sun.com.
Version 1.1.8 of the JDK and version 1.1.8 of the JRE are no longer supported in this release. Near-equivalent capability is supported by Java 2 Standard Edition, versions 1.4 and compatible versions. Current and previous versions of JDK and JRE are available for download from http://java.sun.com.
The Kerberos version 4 client was removed from the Solaris 8 release. This client includes the Kerberos version 4 support in the kdestroy, kerbd, kinit, klist, ksrvtgt , mount_nfs, and share commands. The Kerberos version 4 client also includes support in the kerberos (3KRB) library, and in the ONC RPC programming API kerberos_rpc (3KRB).
For more information, see the kdestroy(1), kinit(1), klist(1), mount_nfs(1M), and share(1M) man pages.
Development in the OpenWindowsTM XViewTM and OLIT toolkits is no longer supported in this release. Developers are encouraged to migrate to the Motif toolkit. Applications that were developed with the OpenWindows XView and OLIT toolkits can still run on the Solaris 9 software.
The OpenWindows environment is no longer supported in this release. The Common Desktop Environment (CDE) is the default desktop environment that is included in the Solaris 9 software. Applications that use the OpenWindows XView and OLIT toolkits can still run on the Solaris 9 software in CDE.
The priority_paging and cachefree tunable parameters are not supported in the Solaris 9 release. These parameters have been replaced with an enhanced file system caching architecture that implements paging policies that are similar to priority paging, but always enabled. Attempts to set these parameters in the /etc/system file result in boot-time warnings such as the following:
sorry, variable 'priority_paging' is not defined in the 'kernel' sorry, variable 'cachefree' is not defined in the 'kernel' |
If you upgrade to the Solaris 9 release or pkgadd the SUNWcsr packages, and your /etc/system file includes the priority_paging or cachefree parameters, the following occurs:
The following message is displayed if the priority_paging or cachefree parameters are set in the /etc/system file:
NOTE: /etc/system has been modified since it contains references to priority paging tunables. Please review the changed file. |
Comments are inserted in the /etc/system file before any line that sets priority_paging or cachefree . For example, if priority_paging is set to 1, this line is replaced with the following lines:
* NOTE: As of Solaris 9, priority paging is unnecessary and * has been removed. Since references to priority paging-related tunables * will now result in boot-time warnings, the assignment below has been * commented out. For more details, see the Solaris 9 Release Notes, or * the "Solaris Tunable Parameters Reference Manual". * set priority_paging=1 |
The s5fs file system is no longer supported in this release. The s5fs file system supports the installation of Interactive UNIX applications, which is no longer required in the Solaris software.
Some features of the sendmail utility are no longer supported in this release. The affected features are modifications that are mostly nonstandard and specific to Sun. These features include special syntax and special semantics for V1/Sun configuration files, the remote mode feature, the AutoRebuildAliases option, and the three sun-reverse-alias features.
More information about these features and migration issues is located at http://www.sendmail.org/vendor/sun/solaris9.html.
The separate patch collections provided in conjunction with the Solaris releases, the Solaris Maintenance Updates (MUs), are no longer supported in this release.
The SUNWebnfs package is no longer included on the Solaris software media.
The library and documentation are available for download from http://www.sun.com/webnfs.
The following servers that are based on the sun4d architecture are no longer supported in this release:
SPARCserverTM 1000
SPARCcenter 2000
Hardware options that are dependent on the sun4d architecture are no longer supported in this release.
The SUNWrdm package, which formerly contained text release notes, is no longer included on the Solaris Software CD in this release.
For release notes, refer to the Release Notes on the Solaris Documentation CD, the printed Installation Release Notes, or the most current release notes that are available on http://docs.sun.com.
