The following features might not be supported in a future release of the Solaris software.
Some of these features have already been removed from Solaris 10 OS software.
The add_drv command accepts a pathname specification for the device_driver parameter. This feature might be removed in a future release.
In the Solaris 9 software, the following warning message is written to STDERR when a path name is specified:
Warning: pathname support will be discontinued in future releases of add_drv. |
During the installation process, warning messages that are generated by the use of the pathname specification appear in the install_log file.
For more information, see the add_drv(1M) man page.
AdminTool (admintool), including swmtool, might not be supported in a future release.
The following Asian short locale names might not be listed in the dtlogin language list in a future release:
zh
zh.GBK
zh.UTF-8
ko
ko.UTF-8
zh_TW
The Solaris 8, Solaris 9, and Solaris 9 9/05 HW releases provide new ISO-standard locale names, which include the following locale names:
zh_CN.EUC
zh_CN.GBK
zh_CN.UTF-8
ko_KR.EUC
ko_KR.UTF-8
zh_TW.EUC
The asysmem() and sysmem() interfaces, which are exported by libadm(3lib), might not be included in a future release. Both interfaces are obsolete. Application developers are advised to use the sysconf(3C) library function instead.
For more information, see the sysconf(3C) man page.
The following interfaces that are used by the Solaris audit daemon might not be supported in a future release:
The following components of the device allocation mechanism of the Basic Security Module might not be included in a future release of the Solaris software:
/etc/security/dev
Some device driver interfaces (DDI) might not be supported in a future release.
The following table lists the DDI interfaces that might not be supported, along with the preferred DDI interface alternatives.
Obsolete Interface |
Preferred Interface |
mmap |
devmap |
identify |
set to nulldev |
copyin |
ddi_copyin |
copyout |
ddi_copyout |
ddi_dma_addr_setup |
ddi_dma_addr_bind_handle |
ddi_dma_buf_setup(9F) |
ddi_dma_buf_bind_handle |
ddi_dma_curwin |
ddi_dma_getwin |
ddi_dma_free |
ddi_dma_free_handle |
ddi_dma_htoc |
ddi_dma_addr[buf]_bind-handle |
ddi_dma_movwin |
ddi_dma_getwin |
ddi_dma_nextseg |
ddi_dma_nextcookie |
ddi_dma_nextwin |
ddi_dma_segtocookie |
ddi_dma_setup |
ddi_dma_*_handle |
ddi_dmae_getlim |
ddi_dmae_getattr |
ddi_getiminor |
getminor |
ddi_getlongprop |
ddi_prop_lookup |
ddi_getlongprop_buf |
ddi_prop_lookup |
ddi_getprop |
ddi_prop_get_in |
ddi_getproplen |
ddi_prop_lookup |
ddi_iopb_alloc |
ddi_dma_mem_alloc |
ddi_iopb_free |
ddi_dma_mem_free |
ddi_mem_alloc |
ddi_dma_mem_alloc |
ddi_mem_free |
ddi_dma_mem_free |
ddi_map_regs |
ddi_regs_map_setup |
ddi_mapdev |
devmap_setup |
ddi_mapdev_intercept |
devmap_load |
ddi_mapdev_nointercept |
devmap_unload |
ddi_prop_create |
ddi_prop_update |
ddi_prop_modify |
ddi_prop_update |
ddi_segmap |
see devmap |
ddi_segmap_setup |
devmap_setup |
ddi_unmap_regs |
ddi_regs_map_free |
free_pktiopb |
scsi_free_consistent_buf |
get_pktiopb |
scsi_alloc_consistent_buf |
makecom_g0 |
scsi_setup_cdb |
makecom_g0_s |
scsi_setup_cdb |
makecom_g1 |
scsi_setup_cdb |
makecom_g5 |
scsi_setup_cdb |
scsi_dmafree |
scsi_destroy_pkt |
scsi_dmaget |
scsi_init_pkt |
scsi_pktalloc |
scsi_init_pkt |
scsi_pktfree |
scsi_destroy_pkt |
scsi_resalloc |
scsi_init_pkt |
scsi_resfree |
scsi_destroy_pkt |
scsi_slave |
scsi_probe |
scsi_unslave |
scsi_unprobe |
ddi_peek{c,s,l,d} |
ddi_peek{8,16,32,64} |
ddi_poke{c,s,l,d} |
ddi_poke{8,16,32,64} |
in{b,w,l} |
ddi_get{8,16,32} |
out{b,w,l} |
ddi_put{8,16,32} |
repins{b,w,l} |
ddi_rep_get{8,16,32} |
repouts{b,w,l} |
ddi_rep_put{8,16,32} |
GLOBAL_DEV |
Specify 0 |
NODEBOUND_DEV |
Specify 0 |
NODESPECIFIC_DEV |
Specify 0 |
ENUMERATED_DEV |
Specify 0 |
DDI_IDENTIFIED |
not needed |
DDI_NOTIDENTIFIED |
not needed |
The Device Management entries in the power.conf file might not be supported in a future release. Similar capability is provided by the Automatic Device Power Management entries in the Solaris 9 software.
For more information, see the power.conf(4) man page.
The following table lists devices and driver software that might not be supported in a future release.
Table 3–2 Device and Driver Software
Name of Physical Device |
Name of Driver |
Type of Card |
AMI MegaRAID host bus adapter, first generation |
mega |
SCSI RAID |
Compaq 53C8x5 PCI SCSI, and Compaq 53C876 PCI SCSI |
cpqncr |
SCSI HBA |
Compaq SMART-2/P Array Controller and Compaq SMART-2SL Array Controller |
smartii |
SCSI RAID controller |
The following nonstandard-input key sequences for the Euro character in Solaris Unicode/UTF-8 locales might not be supported in a future release:
Alt-E
Alt-4
Alt-5
Meta-E
Meta-4
Meta-5
In the key sequences, a hyphen indicates simultaneous keystrokes. A plus sign indicates consecutive keystrokes.
The following are the recommended standard-input key sequences:
Alt Graph-E
Compose+C+=
If the keyboard has no Alt Graph or Compose key, use the following key sequence:
Control-Shift-T+C+=
The Federated Naming Service (FNS), which is based on the X/Open XFN standard, might not be supported in a future release.
The behavior of fork(), when not linked to the -lpthread library, might change in a future release. This behavior change makes Solaris threads consistent with Portable Operating System Interface (POSIX) threads.
The fork() function might be redefined to behave like fork1(). Therefore, fork() would replicate only the calling thread in the child process. This redefinition matches the current behavior of fork1() and of fork() when either are linked with -lpthread .
Support for applications that require the replicate-all behavior of fork() would still be provided.
The Generic LAN Driver (GLD) version 0 interfaces might not be supported in a future release. These interfaces were described in the Solaris 2.1 Device Driver Writer's Guide for x86. Drivers should use the version 2 interfaces that are described in Writing Device Drivers.
The /usr/share/lib/zoneinfo/GMT[+-]* time zones might not be supported in a future release. These files might be removed from /usr/share/lib/zoneinfo . Replace usage of the zoneinfo time zones with the equivalent Etc/GMT[-+]* file.
For more information, see the zoneinfo(4) and environ(5) man pages.
Software support for the following graphic devices might not be provided in a future release:
Device |
Driver |
MG1,MG2 |
bwtwo |
CG3 |
cgthree |
SX/ CG14 |
sx, cgfourteen |
TC |
cgeight |
TCX |
tcx |
Version 1.2.2 of the Java runtime environment (JRE) might not be supported in a future release. Similar capability is supported by Java 2 Standard Edition, version 1.4 and compatible versions. Current and previous versions of JRE are available for download from http://java.sun.com.
Support for the Kodak Color Management System (KCMSTM) might not be available in a future release.
Korean CID fonts might not be supported in a future release. You can use the Korean TrueType fonts that are included in the Solaris software as a replacement for Korean CID fonts.
Lance Ethernet (le) network drivers might not be supported in a future release.
The libXinput.so.0 library might not be provided in a future release of the Solaris software. The libXinput.so.0 library was provided for backward compatibility with X11R4 applications that were built by using the draft standard X Input API of Solaris 2.1 and Solaris 2.2. The X11 standard X Input Extension library, libXi, was integrated in Solaris 2.3.
All applications that rely on the libXi API should be built by using the libXi shared library for future compatibility and standards conformance.
LDAP client library, libldap.so.3, might not be included in a future release. The current version of this library, libldap.so.5, is compliant with the draft-ietf-ldapext-ldap-c-api-05.txt revision of the ldap-c-api draft from the Internet Engineering Task Force (IETF).
The following LWP interfaces might not be supported in a future release:
_lwp_create
_lwp_detach
_lwp_exit
_lwp_getprivate
_lwp_makecontext
_lwp_setprivate
_lwp_wait
These interfaces are not part of a common model with multithreading enabled by default. The interfaces have worked as expected only when used in applications that are not linked with libthread.
For more information, see the _lwp_create(2), _lwp_detach(2), _lwp_exit(2), _lwp_getprivate(2), _lwp_makecontext(2), _lwp_setprivate(2), and _lwp_wait(2) man pages.
The Nameless Interface Groups feature, enabled by ndd /dev/ip ip_enable_group_ifs, might not be supported in a future release. Use the supported IP Network Multipathing feature, which provides similar capability. IP multipathing groups can be formed by using the group keyword of the ifconfig command.
For more information, see the ndd(1M) and ifconfig(1M) man pages.
The unsupported -k option of netstat, which reports on all named kstats on the running OS instance, might be removed in a future release. Use the supported kstat command, which provides similar capability. The kstat command was introduced in the Solaris 8 software.
For more information, see the kstat(1M) man page.
NIS+ might not be supported in a future release. Tools to aid in the migration from NIS+ to LDAP are available in the Solaris 9 software. For more information, visit http://www.sun.com/directory/nisplus/transition.html.
The pam_unix module might not be supported in a future release. Similar capability is provided by pam_authtok_check, pam_authtok_get, pam_authtok_store, pam_dhkeys , pam_passwd_auth, pam_unix_account, pam_unix_auth, and pam_unix_session.
For more information, see the pam_unix(5), pam_authtok_check(5), pam_authtok_get(5), pam_authtok_store(5), pam_dhkeys(5), pam_passwd_auth(5), pam_unix_account(5), pam_unix_auth(5), and pam_unix_session(5) man pages.
Perl version 5.005_03 might not be supported in a future release. In the Solaris 9 release, the default version of Perl has been changed to a version that is not binary compatible with the earlier version (5.005_03). However, the earlier version of Perl is still retained for compatibility. Customer-installed modules need to be rebuilt and reinstalled against the new version. Modify any scripts that require the use of version 5.005_03 to explicitly use the 5.005_03 version of the interpreter (/usr/perl5/5.005_03/bin/perl ) instead of the default version (/bin/perl, /usr/bin/perl, or /usr/perl5/bin/perl).
The following power management I/O control (ioctls) commands might not be supported in a future release:
PM_DISABLE_AUTOPM
PM_REENABLE_AUTOPM
PM_SET_CUR_PWR
PM_GET_CUR_PWR
PM_GET_NORM_PWR
The following alternative ioctls are supported in the Solaris 9 9/05 HW release:
PM_DIRECT_PM
PM_RELEASE_DIRECT_PM
PM_GET_CURRENT_POWER
PM_SET_CURRENT_POWER
PM_GET_FULL_POWER
For more information on these alternative ioctls, see the ioctl(2) man page.
The 64-bit version of the ptrace interface that is included in libc might not be supported in a future release. The proc interface replaces this functionality.
For more information, see the proc(4) man page.
The sendmailvars database that is listed in nsswitch.conf(4) might not be supported in a future release. This feature could not be enabled without using the L or G sendmail.cf commands. This change brings the Sun version of sendmail into closer compliance with the version from sendmail.org.
The Solaris software is currently delivered in separate packages for 32-bit and 64-bit components. The 64-bit packages, introduced in the Solaris 7 release, deliver the 64-bit components of the Solaris software. In general, the 64-bit package name ends with the letter x. For example, SUNWcsl delivers the 32-bit version of the Solaris Core Libraries, and SUNWcslx delivers the 64-bit version.
In a future Solaris release, 32-bit and 64-bit components might be delivered together in a single base package. The combined package retains the name of the original 32-bit package, and the 64-bit package would no longer be delivered. For example, /usr/lib/sparcv9/libc.so.1, which is currently delivered in SUNWcslx, would be delivered in SUNWcsl and SUNWcslx would no longer be delivered.
Some packages only deliver 64-bit components and have no corresponding 32-bit package. In these cases, the packages might be renamed to remove the “ x” suffix. For example, SUNW1394x might become SUNW1394.
The Desktop Java Media player, /usr/dt/bin/sdtjmplay, that is based on the Java Media Framework 1.1, might not be provided in a future release. Users should migrate to /usr/bin/jmplay, the Java Media Player that is based on the newer Java Media Framework 2.1.1 release.
The jmplay Java Media Player is included in the Solaris 9 8/03 and later releases. jmplay is also available for the Solaris 8 and earlier Solaris 9 releases, as part of the GNOME 2.0 Desktop Environment.
The GNOME 2.0 Desktop Environment is available for download by going to http://www.sun.com/gnome/.
The SPC driver might not be supported in a future release.
Many installations of the Solaris 7, 8, and 9 software use the default 64-bit kernel to support 32-bit and 64-bit applications. Customers who use the 32-bit kernel on UltraSPARC systems should read this notice.
In the Solaris 7, 8 and 9 releases, all systems that are based on the UltraSPARC I and UltraSPARC II processors provide administrators the choice of booting a 32-bit kernel or a 64-bit kernel. The UltraSPARC III and later systems support only the 64-bit kernel.
In a future release of the Solaris software, the 32-bit kernel might not be available for the UltraSPARC I and UltraSPARC II systems.
The primary impact of these changes is to systems that rely on third-party, 32-bit kernel modules: firewalls, kernel-resident drivers, and replacement file systems, for example. These systems must be updated to use 64-bit versions of those modules.
Another impact of these changes is that UltraSPARC systems that contain UltraSPARC I processors with clocks that run at 200 MHz or lower frequencies might not be supported in a future release.
To identify the system's kernel type, use the isainfo(1) command.
% isainfo —kv
To identify the system's processor clock rate, use the psrinfo(1M) command.
% psrinfo —v | grep MHz
This announcement applies only to 32-bit static-system libraries and statically linked utilities. 64-bit static system libraries and utilities have never been provided.
Support for 32-bit Solaris static-system libraries and statically linked utilities might not be provided in a future release. Of particular note, support for the static C library (/usr/lib/libc.a) might not be provided in a future release.
Applications that are linked with existing static system libraries might not work in a future release. Only applications that are dynamically linked with the system libraries that provide the Solaris application binary interface (ABI) are designed for future compatibility.
Applications that depend on the behavior of system traps might not work in a future release. Applications that link with libraries that depend on the behavior of system traps, typically libraries providing substitute ABI functions, also might not work in a future release.
Solaris Volume Manager's Transactional Volumes (trans metadevices) might not be supported in a future release to reduce redundancy on the Solaris feature set. Similar capability is provided by UFS Logging, included in the Solaris 8 software, and compatible versions.
Solstice Enterprise Agents might not be supported in a future release.
The /usr/sbin/in.rdisc implementation of the IPv4 ICMP Router Discovery protocol might not be supported in a future release of the Solaris software. A near-equivalent version of this protocol, which is implemented as a component of /usr/sbin/in.routed, supports an enhanced administrative interface. The /usr/sbin/in.routed component supports the implementation of Routing Information Protocol (RIP) version 2. The /usr/sbin/in.routed component also has the ability to distinguish Mobile IP advertisements from Router Discovery messages.
The following interfaces for device driver properties might not be supported in a future release:
fast-writes (pln driver property)
priority-reserve (pln driver property)
The following device drivers might not be supported in a future release:
/kernel/drv/pln
/kernel/drv/pln.conf
/kernel/drv/sparcv9/pln
/kernel/drv/soc
/kernel/drv/sparcv9/soc
The following utility might not be supported in a future release:
/usr/sbin/ssaadm
sun4m hardware might not be supported in a future release.
Version 7.0 of Sun Java System Application Server Platform Edition might not be supported in a future release. Similar capability is provided by Sun Java System Application Server Platform Edition 8 and compatible versions.
While most Java 2 Platform, Enterprise Edition (J2EE) applications will run unchanged in the Sun Java System Application Server Platform Edition 8, applications that use proprietary unstable APIs will require modification.
Software support for the following storage devices might not be provided in a future release of the Solaris software:
Sun StorEdgeTM A3000 system
Sun StorEdge A3500 system
Sun StorEdge A3500FC system
The following tape devices might not be supported in a future release:
Sun StorEdge DLT4700 Tape Autoloader
Sun StorEdge L140 Tape Library
Sun StorEdge L280 Tape Autoloader
Sun StorEdge L400 Tape Library
Sun StorEdge L1800 Tape Library
Sun StorEdge L3500 Tape Library
Sun StorEdge L11000 Tape Library
Support for the UltraTM AX and the SPARCengine Ultra AXmp graphics card might not be provided in a future release of the Solaris software
Static libraries in /usr/openwin/lib might not be supported in a future release of the Solaris software. Support for 32-bit static libraries in /usr/openwin/lib and programs that are statically linked with those libraries might not be provided in a future release. Sixty-four-bit static libraries have never been provided.
Applications that are linked with existing static libraries in /usr/openwin/lib might not work in a future release. Only applications that are dynamically linked with the shared libraries that provide the Solaris application binary interface (ABI) are designed for future compatibility.
The XILTM interface might not be supported in a future release. An application that uses XIL causes the following warning message to be displayed:
WARNING: XIL OBSOLESCENCE This application uses the Solaris XIL interface which has been declared obsolete and may not be present in version of Solaris beyond Solaris 9. Please notify your application supplier. The message can be suppressed by setting the environment variable "_XIL_SUPPRESS_OBSOLETE_MSG. |
The xetops utility might not be supported in a future release. The xetops utility converts an Asian text file to a PostScript file. This conversion enables Asian characters to be printed on PostScript printers that do not have resident Asian fonts.
Similar capability is provided in the mp command, which has been enhanced to support all of the native Asian encodings with more options and functionality.
The xutops print filter might not be supported in a future release. Similar capability is provided by the mp print filter in the Solaris 9 9/05 HW release.
For more information, see the mp(1) man page.
