The following Documentation CD issues apply to the Solaris 9 9/05 HW release.
In the iPlanetTM Directory Server 5.1 Collection (Solaris Edition), links titled DocHome do not work. In addition, links between separate books do not work. If you select these links, your browser displays a Not Found error.
Workaround: To navigate between iPlanet Directory Server 5.1 documents on your system, go to the iPlanet Directory Server 5.1 Collection (Solaris Edition) page at http://docs.sun.com. Click the link to the document you want to view.
If you remove the SUNWsdocs package, then try to remove other documentation packages, the removal fails. This problem occurs because the SUNWsdocs package is installed with any collection and provides the browser entry point.
Workaround: If you removed the SUNWsdocs package, reinstall the SUNWsdocs package from the documentation media and then remove the other documentation packages.
