Solaris 9 9/05 HW Release Notes
Documentation CD Bugs
The following Documentation CD bugs apply to the Solaris 9 9/05 HW release.
European Locale PDF Documents Available Only Through C Locale (4674475)
In the Solaris 9 9/05 HW software and other systems based on UNIX, PDF documents on the Solaris 9 9/05 HW Documentation 1 of 2 CD are not accessible in the following European locales:
This problem occurs because of a limitation with Adobe Acrobat Reader. For more information on this problem, see the Adobe Technote site at http://www.adobe.com:80/support/techdocs/294de.htm.
Workaround: Choose one of the following workarounds.
Removing Solaris 9 9/05 HW Documentation Packages Might Unexpectedly Uninstall Some Solaris 9 9/05 HW Documentation Collections (4641961)
Some Solaris 9 9/05 HW documentation collections might be unexpectedly removed from your system under the following circumstances:
  1. You install both the Solaris 9 9/05 HW Documentation 1 of 2 and 2 of 2 CDs on your system.
  2. You then use the prodreg utility or the Solaris 9 9/05 HW Documentation CD installer program to remove certain documentation packages.
The Solaris 9 9/05 HW Documentation CD 1 of 2 and 2 of 2 have three collections in common. If you remove the packages that contain these collections from either of the Solaris 9 9/05 HW Documentation 1 of 2 or 2 of 2 CD installations, the package is removed for both installations.
The following table lists the packages that might be removed unexpectedly.
Table 2–2 Solaris 9 9/05 HW Documentation Packages Contained on Both Solaris 9 9/05 HW Documentation CDs
HTML Package Names
PDF Package Names
Collection Description
SUNWaadm
SUNWpaadm
Solaris 9 System Administrator Collection
SUNWdev
SUNWpdev
Solaris 9 Developer Collection
SUNWids
SUNWpids
iPlanet Directory Server 5.1 Collection
Workaround: Choose one of the following workarounds:
