Java Dynamic Management Kit 5.1 Getting Started Guide
Authenticated Requests
The agent checks the identity of the originator of the request as previously described and then checks the timeliness of the request to ensure that it has not been delayed or intercepted for improper purposes. To monitor the timeliness of the arrival of requests, both manager and agent maintain synchronized clocks, and the manager's local notion of the authoritative engine's time of sending is included in the request. If the difference between the time of sending included in the request and the time of receipt recorded by the agent exceeds 150 seconds, then the request is not considered timely and is rejected.
Once the timeliness of the request has been confirmed, the request is authenticated using either of the HMAC-MD5 or HMAC-SHA protocols. These protocols check that the message digest included in the message matches the one computed locally in the receiving agent.
