If any of the preceding checks fail, one of the following errors will be generated:
Unregistered user
Unregistered SNMP entity
Encryption error
Unsupported security level
Password error
Timeliness error
You can optionally implement alternative authentication and encryption algorithms. You cannot, however, plug in customized security or access control models in Java Dynamic Management Kit 5.1, although this will be possible in future versions.
