Getting Started with the Java Dynamic Management Kit 4.2
Model MBeans
A model MBean is a generic, configurable, dynamic MBean which you can use to instrument a resource at runtime. A model MBean is an MBean template: the caller tells the model MBean what management interface to expose. The caller also determines how attributes and operations are implemented by designating a target object on which attribute access and operation invocation are actually performed.
The model MBean implementation class is mandated by the JMX specification, and therefore it is always available for instantiation in an agent. Management applications can use model MBeans to instrument resources on-the-fly.
To instrument a resource and expose it dynamically, you need to:
The management interface of a model MBean is dynamic, and it is also exposed dynamically. The application which configures a model MBean may modify its management interface at any time. It may also change its implementation by designating a new target object.
Management applications access all types of MBeans in the same manner, and most applications are not aware of the different MBean types. However, if a manager understands model MBeans, it will be able to obtain additional management information about the managed resource. This informations includes behavioral and runtime metadata that is specific to model MBeans.
