Topology Change and Topology Change Detection
Set Spanning Tree Compatibility to STP
Restore Spanning Tree Compatibility
Restore the Default Bridge Priority
Configuring the STP Port Priority
Port Priority Configuration Topology Example
Restore the Default Port Priority
Configuring the Spanning Tree Link Type
Spanning Tree Link Type Overview
Configure the Interface Link Type
Restore the Default Interface Link Type
Configuring the Spanning Tree Portfast Port
Spanning Tree Portfast Port Overview
Restore the Default Portfast Port
Configuring Spanning Tree Timers
Restore the Default Timer Values
Configuring the Pseudo Root ID
Display Spanning Tree Information for Active Ports
Display Detailed Spanning Tree Information
Display the Spanning Tree Port-Specification Configuration
Display a Summary of the Spanning Tree Information for the Configuration
Specify MST Forward Time, Hello Time, and Max Age
Set the Spanning Tree Operating Mode
Specify MST Mode Configurations
Configuring the Spanning Tree Switch Priority
Configure the Spanning Tree Switch Priority
Restore the Default Spanning Tree Priority
Configure MST Properties of an Interface
Restore the Default MSTP Priority
Configuring the Interval Between Generation of Configuration Messages
Configure the MST Interval Between Generation of Configuration Messages
Restore the Default Interval Between Generation of Configuration Messages
Configuring the Maximum Hop Count
Configure the Maximum Hop Count
Restore the Default Maximum Hop Count
Configuring Features Common to RSTP and MSTP
Configuring the Transit Hold Count
Configure the Transmit Hold Count
Restore the Default Transmit Hold Count Value
Configuring the Dynamic Path Cost
Dynamic Path Cost Topology Example
Configure the Dynamic Path Cost
Configure the Dynamic Path Cost in an Aggregate Port
Disable the Dynamic Path Cost Calculation
Configure the Dynamic Path Cost Lag Speed in an Aggregate Port
Disable the Dynamic Path Cost Lag Speed Calculation
Enable Spanning Tree Loop Guard
Show Spanning Tree Performance Data
Configuring Automatic Detection of Edge Devices or Bridges
Configure Automatic Detection of Edge Devices or Bridges
Disable Automatic Detection of Edge Devices or Bridges
Configuring the Restricted Role
Configuring the Topology Change
Restart the Protocol Migration Process
Configuring the Spanning Tree BPDU Receive Status
Configure the Spanning Tree BPDU Receive Status
Disable the Spanning Tree BPDU Receive Status
Configuring the Spanning Tree BPDU Transmit Status
Configure the Spanning Tree BPDU Transmit Status
Disable the Spanning Tree BPDU Transmit Status
Configuring the Spanning Tree L2GP Status
Configure the Spanning Tree L2GP Status
Display the Spanning Port Information
Display the MST Configuration and Status
Topology After Configuring the Bridge Priority and Port Path Cost in RSTP
SEFOS# show spanning-tree detail Spanning tree Protocol Enabled. MST00 is executing the mstp compatible Multiple Spanning Tree Protocol Bridge Identifier has Priority 32768, Address 00:01:02:03:04:01 Configured Max age 20 sec, Forward delay 15 sec Configured Hello Time 2 sec Dynamic Path Cost Disabled Flush Interval 0 centi-sec, Flush Invocations 72 Flush Indication threshold 0 Current Root has priority 32768, address 00:02:02:03:04:01cost of root path is 2000Number of Topology Changes 1, Time since topology Change 89 seconds agoTransmit Hold-Count 3Root Times : Max age 20 Sec Forward delay 15 SecPort 45 [Ex0/45] of MST00 is Root , ForwardingEx0/45 is operating in the MSTP ModePort path cost 2000, Port priority 128,Port Identifier 128.45. Port HelloTime 2,Timers: Hello - 1, Forward Delay - 0, Topology Change - 0Designated root has priority 32768, address 00:02:02:03:04:01 Designated Bridge has priority 32768, address 00:02:02:03:04:01 Designated Port Id is 128.45, Designated pathcost is 0Operational Forward delay 15, Max age 20Received Hello Time 2 SecNumber of Transitions to forwarding State : 1Auto-Edge is enabledPortFast is disabled, Oper-Edge is disabledLink type is point to PointBPDUs : sent 4, recieved 4466Restricted Role is disabled.Restricted TCN is disabled.bpdu-transmit enabledbpdu-receive enabledLoop Guard is disabled
SEFOS(config)# clear spanning-tree mst 1 counters SEFOS(config)# end
SEFOS# sh spanning-tree detail Spanning tree Protocol has been enabled MST00 is executing the mstp compatible Multiple Spanning Tree Protocol Bridge Identifier has Priority 32768, Address 00:01:02:03:04:01Configured Max age 20 sec, Forward delay 15 secConfigured Hello Time 2 secDynamic Path Cost DisabledFlush Interval 0 centi-sec, Flush Invocations 219Flush Indication threshold 0 Current Root has priority 32768, address 00:02:02:03:04:01cost of root path is 2000Number of Topology Changes 6, Time since topology Change 2 secs agoTransmit Hold-Count 3Root Times : Max age 20 Sec Forward delay 15 Sec Port 46 [Ex0/46] of MST00 is Root , ForwardingEx0/46 is operating in the MSTP ModePort path cost 2000, Port priority 128,Port Identifier 128.46. Port HelloTime 2,Timers: Hello - 0, Forward Delay - 0, Topology Change - 0 Designated root has priority 32768, address 00:02:02:03:04:01Designated Bridge has priority 32768, address 00:02:02:03:04:01Designated Port Id is 128.46, Designated pathcost is 0Operational Forward delay 15, Max age 20 Received Hello Time 2 SecNumber of Transitions to forwarding State : 2Auto-Edge is enabledPortFast is disabled, Oper-Edge is disabled Link type is point to PointBPDUs : sent 19, recieved 282Restricted Role is disabled.Restricted TCN is disabled.bpdu-transmit enabledbpdu-receive enabled Loop Guard is disabled MST01 is executing mstp compatible spanning-tree protocolFlush Invocations 0Flush Indication threshold 0 Port 46 [Ex0/46]of MST01 is Master, ForwardingPort cost 2000, Port priority 128,Port Identifier 128.46. Port HelloTime 2,Timers: Hello - 0,Forward Delay - 0, Topology Change - 0Designated Root has priority 32768, address 00:01:02:03:04:01 Designated Bridge has priority 32768, address 00:01:02:03:04:01Designated Port Id is 128.46, Designated pathcost is 0Operational Forward delay 15, Max age 20Number of Transitions to forwarding State : 0BPDUs : sent 0, recieved 0
