Enable IGS on a Specific VLAN Interface
Configure Multicast Forwarding Mode
Configuring a Multicast Router Port
Disable a Multicast Router Port
Configure the Multicast Router Port Time-Out Value
Configuring IGS Querier Settings
Configure the IGMP Snooping Query Interval
Configuring the Port-Purge Interval
Disable the Fast Leave Process
Configuring the Report Suppression Interval
Enable the Report Suppression Interval
Disable the Report Suppression Interval
Configuring the Group Query Interval Value
Set the Group Query Interval Value
Reset the Group Query Interval
Configuring the Group Retry Count Value
Set the Group Retry Count Value
Reset the Group Retry Count Value
Reset Report Forwarding to the Default Value
Clearing the Snooping Statistics
Clear the Statistics for a Specific VLAN
Clear the Statistics for All VLANs
Configuring the General Query Transmission Option
Enable the General Query Transmission Option
Disable the General Query Transmission Option
Flow-Based Configuration Example
Configure the MAC-Based Multicast Forwarding Mode
Configure the IP-Based Multicast Forwarding Mode
Configure a Static Router Port
SEFOS# show ip igmp snooping statistics Snooping Statistics for VLAN 1 General queries received: 0 Group specific queries received: 0 Group and source specific queries received: 0 ASM reports received: 2 SSM reports received: 0 IS_INCLUDE messages received: 0 IS_EXCLUDE messages received: 0 TO_INCLUDE messages received: 0 TO_EXCLUDE messages received: 0 ALLOW messages received: 0 Block messages received: 0 Leave messages received: 0 General queries transmitted: 0 Group specific queries transmitted: 0 ASM reports transmitted: 0 SSM reports transmitted: 0 Leaves transmitted: 0 Unsuccessful joins recieved count Per Vlan : 0 Active/Successful joins recieved count Per Vlan: 0 Active Groups count: 0 Packets dropped: 0
