Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
IGS Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
IGS Overview
IGS Protocol Description
Topology Example
Configuration Prerequisites
Default Settings
Configuring IGS
Enabling and Disabling IGS
Enable IGS Globally
Enable IGS on a Specific VLAN Interface
Disable IGS
Configure Multicast Forwarding Mode
Configure the IGS Version
Configuring a Multicast Router Port
Enable Multicast Router Port
Disable a Multicast Router Port
Configure the Multicast Router Port Time-Out Value
Configuring IGS Querier Settings
Enable IGS as a Querier
Configure the IGMP Snooping Query Interval
Configuring Proxy Reporting
Disable Proxy Reporting
Enable Proxy Reporting
Configuring the Port-Purge Interval
Set the Port-Purge Interval
Reset the Port-Purge Interval
Configuring Leave Processing
Enable the Fast Leave Process
Disable the Fast Leave Process
Configuring the Report Suppression Interval
Enable the Report Suppression Interval
Disable the Report Suppression Interval
Configuring the Group Query Interval Value
Set the Group Query Interval Value
Reset the Group Query Interval
Configuring the Group Retry Count Value
Set the Group Retry Count Value
Reset the Group Retry Count Value
Configuring Report Forwarding
Enable Report Forwarding
Disable Report Forwarding
Reset Report Forwarding to the Default Value
Clearing the Snooping Statistics
Clear the Statistics for a Specific VLAN
Clear the Statistics for All VLANs
Configuring the General Query Transmission Option
Enable the General Query Transmission Option
Disable the General Query Transmission Option
Display Statistics
Flow-Based Configurations
Flow-Based Configuration Example
Configuration Parameters
Configure the MAC-Based Multicast Forwarding Mode
Configure the IP-Based Multicast Forwarding Mode
Configure a Static Router Port
Configure Queriers in Flow-Based Configurations
Configure Proxy Reporting in Flow-Based Configurations
If you have questions about the topology used in this section, see Flow-Based Configuration Example. For the default settings, see Default Settings.
  1. On DUT1, configure the multicast forwarding mode for IGS as MAC-based.
    SEFOS# configure terminal
    SEFOS(config)# snooping multicast-forwarding-mode mac
  2. Disable GMRP.
    SEFOS(config)# set gmrp disable
  3. Enable IGS.
    SEFOS(config)# ip igmp snooping
  4. Configure VLAN 2 in the switch.
    SEFOS(config)# vlan 2
  5. Configure the static VLAN entry (VLAN 2) with the required ports.
    SEFOS(config-vlan)# ports extreme-ethernet 0/1-4
    SEFOS(config-vlan)# exit
  6. Enter the Interface Configuration mode for Gigabit Ethernet interface 0/1.
    SEFOS(config)# interface extreme-ethernet 0/1
  7. Set the port VLAN ID as VLAN 2.
    SEFOS(config-if)# switchport pvid 2
  8. Bring up the interface.
    SEFOS(config-if)# no shutdown
    SEFOS(config-if)# exit
  9. Enter Interface Configuration mode for Gigabit Ethernet interface 0/2.
    SEFOS(config)# interface extreme-ethernet 0/2
  10. Set the PVID as VLAN 2.
  11. Bring up the interface.
  12. Enter Interface Configuration mode for Gigabit Ethernet interface 0/3.
    SEFOS(config)# interface extreme-ethernet 0/3
  13. Set the PVID as VLAN 2.
  14. Bring up the interface.
  15. Enter the interface configuration mode for Gigabit Ethernet interface 0/4.
    SEFOS(config)# interface extreme-ethernet 0/4
  16. Set the PVID as VLAN 2.
  17. Bring up the interface.
    SEFOS(config-if)# end
  18. Review the IGS-related configurations.
    SEFOS# show ip igmp snooping globals
    Snooping Configuration
    IGMP Snooping globally enabled
    IGMP Snooping is operationally enabled
    IGMP Snooping Enhanced mode is disabled
    Transmit Query on Topology Change globally disabled
    Multicast forwarding mode is MAC based
    Proxy globally disabled
    Proxy reporting globally enabled
    Filter is disabled
    Router port purge interval is 125 seconds
    Port purge interval is 260 seconds
    Report forward interval is 5 seconds
    Group specific query interval is 2 seconds
    Reports are forwarded on router ports
    Group specific query retry count is 2
    Multicast VLAN disabled
    Leave config level is Vlan based
  19. Review the VLAN information.
    SEFOS# show vlan id 2
    Vlan database-------------------Vlan ID                 : 2Member Ports            : Ex0/1, Ex0/2, Ex0/3, Ex0/4Untagged Ports          : NoneForbidden Ports         : NoneName                    :Status                  : Permanent----------------------------------------------------
  20. Send V1, V2, and V3 join messages for group MG1 (227.1.1.1) from host A and host C.
  21. Review the forwarding database.
    SEFOS# show ip igmp snooping forwarding-database
    Vlan      MAC-Address          Ports ------  -------------------    --------    2    01:00:5e:01:01:01       Ex0/2, Ex0/4
  22. Send multicast data packets for MG1 (227.1.1.1) from SRC A.
    The multicast data packet should be received only on host A and host C.
