| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System VRRP Administration Guide |
Create VRRP Instance Over an Interface
Configure Additional Associated IP Addresses to a VRRP Instance
Configure Authentication Password for VRRP Tickets
Refer to the Sun Ethernet Fabric Operating System CLI Enterprise Reference Manual for a complete set of commands and options for configuring VRRP.
The command vrrp vrid(1-255) ipv4 ip-address must be entered for the current interface (with the correct vrid) before the execution of any commands in Interface Configuration mode.
This section shows the default configuration values:
