| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System VRRP Administration Guide |
Create VRRP Instance Over an Interface
Configure Authentication Password for VRRP Tickets
A VRRP instance can be associated with more than one IP address. When the router becomes master for an instance, then it replies to the ARP request(s) for all the associated IP addresses.
See the first figure in VRRP Topology for the topology used in this example.
SEFOS# configure terminal
SEFOS(config)# router vrrp
SEFOS(config-vrrp)# interface vlan 2
SEFOS(config-vrrp-if)# vrrp 1 ipv4 12.0.0.5
SEFOS(config-vrrp-if)# vrrp 1 ipv4 12.0.0.6 secondary
SEFOS(config-vrrp-if)# end
SEFOS# show vrrp interface vlan 2 detail vlan2 - vrID 1 --------------- State is Backup Virtual IP address is 12.0.0.5 Virtual MAC address is 00:00:5e:00:01:01 Master router is 12.0.0.5 Associated IpAddresses : ---------------------- 12.0.0.5 12.0.0.6 Advertise time is 1 secs Current priority is 100 Configured priority is 100, may preempt Accept Mode Disabled
SEFOS# show vrrp interface vlan 2 detail vlan2 - vrID 1 --------------- State is Master Virtual IP address is 12.0.0.5 Virtual MAC address is 00:00:5e:00:01:01 Master router is 12.0.0.5 Associated IpAddresses : ---------------------- 12.0.0.5 12.0.0.6 Advertise time is 1 secs Current priority is 100 Configured priority is 100, may preempt Accept Mode Disabled
Maximum number of associated IP addresses per instance is 10.
