| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS REM HBA Installation Guide For HBA Models SGX-SAS6-REM-Z and SG-SAS6-REM-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Chapter 4 HBA Software Installation
This appendix contains the specifications for the HBA. This appendix contains the following topics:
The HBA board is 4.5-in. x 5.5-in. The PCIe and SAS/SATA interface connections are through a mezzanine connector, J1. It conforms to the PCIe Card Electromechanical Specification 2.0.
The PCI Express features of the HBA include the following:
Provides a scalable interface
Single-lane aggregate bandwidth of up to 0.5 GB/s (500 MB/s)
Quad-lane aggregate bandwidth of up to 2 GB/s (2000 MB/s)
8-lane aggregate bandwidth of up to 4.0 GB/s (4000 MB/s)
Supports serial point-to-point interconnections between devices
Supports lane reversal and polarity inversion
Supports the PCI Express advanced error reporting capabilities
Uses a packetized and layered architecture
Achieves a high bandwidth per pin with low overhead and low latency
PCI Express is software compatible with PCI and PCI-X software
Leverages existing PCI device drivers
Supports the memory, I/O, and configuration address spaces
Supports memory read/write transactions, I/O read/write transactions, and configuration read/write transactions
Provides 4-KB of PCI configuration address space per device
Supports posted and nonposted transactions
Supports traffic class 0 and class 1 virtual channel
Supports message signaled interrupts (both MSI and MSI-X) as well as INTx interrupt signaling for legacy PCI support
Supports end-to-end CRC (ECRC) and advanced error reporting
The HBA supports narrow and wide ports, as described in the following table.
The HBA environmental requirements are listed in HBA Environmental Specifications.
The HBA provides 6 Gb SAS performance using the HBA controller for Oracle-specified servers. The board has on-board Flash ROM for firmware and BIOS, and NVSRAM for embedded mirroring. Each of the eight PHYs on the HBA is capable of 6 Gb, 3 Gb, or 1.5 Gb SAS or SATA link rates.
The board has eight activity LEDs that blink green for SAS activity, eight port-fault LEDs that are solid yellow, indicating a faulty link in the port, and one Heartbeat LED that blinks green for firmware heartbeat and indicates the card is capable of general activity.
This section provides a description of the different connectors on the host bus adapter.
SAS/SATA and PCIe Mezzanine Connector (J1). Supports x8 PCIe interface and a x8 SAS/SATA interface.
UART Connector (J4). Debug port requiring a special cable and Oracle support to gather detailed IOC status.
UART Connections lists the UART connections and their functions.
