Because CUPS accounting
information is usually not necessary, you can disable the accounting functionality
in the cupsomatic filter. Perform the following steps:
Log in as root user.
Open the following file: /usr/lib/cups/filter/cupsomatic
Change the following line:
my $ps_accounting = 1;
To:
my $ps_accounting = 0;
If you use/etc/foomatic/filter.conf,
disable ps_accounting in that location.
