Problem |
The Blueprint Beta theme is for evaluation only. Do not use the Blueprint Beta theme under normal circumstances. This theme has known bugs and is not supported. |
Solution |
If you want to evaluate the Blueprint Beta theme, choose ViewApply ThemeBlueprint Beta. |
