The Nautilus file manager might crash if a directory
structure is longer than 290 plain Latin characters.
Solution
Do not create directory
structures longer than 290 plain Latin characters, if you want to access the
directory structures using the Nautilus file manager.
There is no limitation to the character length of a directory structure when
you browse the file system using the Terminal application.
