Bug ID: 5017762
After you have performed an installation to update an earlier version of the Java Desktop System the Input Method Switcher
applet is not added to the default panel. A symptom of this problem is that
boxes are attached to windows.
The default panel configuration
on Java Desktop System Release 2 is different from
earlier releases of the Java Desktop System. You
might experience this problem if you log into an earlier version of the Java Desktop System.
