Bug ID: 5028130
After you have performed an installation to update an earlier version of the Java Desktop System, the file system RPM fails to install.
This problem occurs when you perform a YaST2
system update from CDs, with the default automount enabled in the Nautilus file manager. The problem also occurs when you perform
a YaST2 system NFS update when a CD is mounted
at /media/cdrom.
This problem does not occur
when you perform a network update, after booting from a CD.
