Boot Splash Screen Not Visible After Updating the Installation
Problem
Bug ID: 5026577
After you have performed an installation to update an earlier version of the Java Desktop System, the boot splash screen does not appear.
This problem is caused by a missing link in the /usr/share/splash/themes directory.
Solution
Perform the following
steps:
Log in as root user.
Execute the following command: cd /usr/share/splash/theme
Execute the following command: execute ln -s Sun
current
