Java Desktop System Release 2 Troubleshooting Guide
PPP Connection Does Not Work
Problem
You cannot connect to the network using a dial-up PPP connection.
Solution
If you are using a modem for your network connection, and you require a dial up PPP connection, use the Linux PPP dialer command utility wvdial.
