| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS ExpressModule HBA Installation Guide For HBA Models SGX-SAS6-EM-Z and SG-SAS6-EM-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Chapter 4 HBA Software Installation
Acronym for Basic Input/Output System. Software that provides basic read/write capability. Usually kept as firmware (ROM-based). The system BIOS on the motherboard of a computer boots and controls the system. The BIOS on your host adapter acts as an extension of the system BIOS.
Refers to the way a computer is set up, the combined hardware components (computer, monitor, keyboard, and peripheral devices) that comprise a computer system, or the software settings that enable the hardware components to communicate with each other.
A program that enables a microprocessor (through the operating system) to direct the operation of a peripheral device.
A software procedure in which a host queries a device to determine its ability to communicate at the negotiated data rate.
A group of physical drives that combines the storage space on the drives into a single segment of storage space. A hot-spare drive does not actively participate in a drive group.
Acronym for electronically erasable programmable read-only memory. It is a memory chip that typically stores configuration information, as it provides stable storage for long periods without electricity and can be reprogrammed. Refer to NVRAM.
A SAS device installed outside the computer cabinet. These devices are connected using specific types of shielded cables.
An acronym for Fusion-Message Passing Technology architecture. Fusion-MPT consists of several main elements: Fusion-MPT firmware, the Fibre Channel and SCSI hardware, and the operating system level drivers that support these architectures. Fusion-MPT architecture offers a single binary, operating system driver that supports both Fibre Channel and SCSI devices.
The computer system in which a RAID adapter is installed. It uses the RAID adapter to transfer information to and from devices attached to the SCSI bus.
A circuit board or integrated circuit that provides a device connection to the computer system.
An idle, powered-on, standby drive that is ready for immediate use in case of drive failure. A hot spare does not contain any user data. A hot spare can be dedicated to a single redundant array or it can be part of the global hot‐spare pool for all arrays managed by the adapter.
When a drive fails, the adapter firmware automatically replaces and rebuilds the data from the failed drive to the hot spare. Data can be rebuilt only from virtual drives with redundancy (RAID levels 1, 5, 6, 10, 50, and 60; not RAID level 0), and the hot spare must have sufficient capacity.
A SAS device installed inside the computer cabinet. These devices are connected using a shielded cable.
The part of computer memory that is directly accessible by the CPU (usually synonymous with RAM).
Acronym for nonvolatile random access memory. An EEPROM (electronically erasable read-only memory) chip that stores configuration information. Refer to EEPROM.
Acronym for peripheral component interconnect. A high-performance, local bus specification that enables the connection of devices directly to computer memory. The PCI Local Bus enables transparent upgrades from 32-bit data path at 33 MHz to 64-bit data path at 33 MHz, and from 32‐bit data path at 66 MHz to 64-bit data path at 66 MHz.
Acronym for peripheral component interconnect Express. A high‐ performance, local bus specification that enables the connection of devices directly to computer memory. PCI Express is a two-way, serial connection that transfers data on two pairs of point-to-point data lines. PCI Express goes beyond the PCI specification in that it is intended as a unifying I/O architecture for various systems: desktops, workstations, mobile, server, communications, and embedded devices.
A piece of hardware (such as a video monitor, drive, printer, or CD‐ROM) used with a computer and under the control of the computer. SCSI peripherals are controlled through a MegaRAID SAS RAID controller (host adapter).
The interface required to transmit and receive data packets transferred across the serial bus.
Each PHY can form one side of the physical link in a connection with a PHY on a different SATA device. The physical link contains four wires that form two differential signal pairs. One differential pair transmits signals, while the other differential pair receives signals. Both differential pairs operate simultaneously and enable concurrent data transmission in both the receive and the transmit directions.
Acronym for serial attached SCSI. A serial, point-to-point, enterprise‐level device interface that leverages the proven SCSI protocol set. The SAS interface provides improved performance, simplified cabling, smaller connections, lower pin count, and lower power requirements when compared to parallel SCSI. SAS adapters leverage a common electrical and physical connection interface that is compatible with Serial ATA. The SAS adapters support the ANSI Serial Attached SCSI Standard, Version 2.0. In addition, the adapter supports the Serial ATA II (SATA II) protocol defined by the Serial ATA Specification, Version 1.0a. Supporting both the SAS interface and the SATA II interface, the SAS adapter is a versatile adapter that provides the backbone of both server and high-end workstation environments. Each port on the SAS RAID adapter supports SAS devices, SATA II devices, or both.
Any device that conforms to the SAS standard and is attached to the SAS bus by a SAS cable. This includes SAS RAID adapters (host adapters) and SAS peripherals.
Acronym for Serial Advanced Technology Attachment. A physical storage interface standard, SATA is a serial link that provides point-to-point connections between devices. The thinner serial cables enable better airflow within the system and permit smaller chassis designs.
Acronym for Serial Management Protocol. SMP communicates topology management information directly with an attached SAS expander device. Each PHY on the adapter can function as an SMP initiator.
A method for combining multiple drives into a single logical drive. If you want to have all of the drive capacity in one drive group, you can span (merge) the drives so that the operating system sees just one large drive. For more information, refer to the MegaRAID SAS Software User's Guide, located at: http://www.lsi.com/sep/Pages/oracle/index.aspx.
Acronym for Serial SCSI Protocol. SSP enables communication with other SAS devices. Each PHY on the SAS adapter can function as an SSP initiator or SSP target.
Acronym for Serial Tunneling Protocol. STP enables communication with a SATA II device through an attached expander. Each PHY on the SAS adapter can function as an STP initiator.
The total drive space consumed by a stripe not including a parity drive. For example, consider a stripe that contains 64 Kbytes of drive space and has 16 Kbytes of data residing on each drive in the stripe. In this case, the stripe size is 64 Kbytes and the stripe element size is 16 Kbytes. The stripe depth is four (four drives in the stripe). You can specify stripe sizes of 8 Kbytes, 16 Kbytes, 32 Kbytes, 64 Kbytes, 128 Kbytes, 256 Kbytes, 512 Kbytes, or 1 Mbyte for each logical drive. A larger stripe size produces improved read performance, especially if most of the reads are sequential. For mostly random reads, select a smaller stripe size.
Drive striping writes data across two or more drives. Each stripe spans two or more drives but consumes only a portion of each drive. Each drive, therefore, may have several stripes. The amount of space consumed by a stripe is the same on each drive that is included in the stripe. The portion of a stripe that resides on a single drive is a stripe element. Striping by itself does not provide data redundancy; striping in combination with parity provides data redundancy.
A storage unit created by a RAID controller from one or more drives. Although a virtual drive may be created from several drives, it is seen by the operating system as a single drive. Depending on the RAID level used, the virtual drive can retain redundant data in case of a drive failure.
