| Skip Navigation Links | |
| Exit Print View | |
man pages section 3: Curses Library Functions Oracle Solaris 11 Express 11/10 |
- set and get forms field attributes
cc [ flag... ] file... -lform -lcurses [ library... ] #include <form.h> int set_field_buffer(FIELD *field, int buf, char *value);
char *field_buffer(FIELD *field, int buf);
int set_field_status(FIELD *field, int status);
int field_status(FIELD *field);
int set_max_field(FIELD *field, int max);
set_field_buffer() sets buffer buf of field to value. Buffer 0 stores the displayed contents of the field. Buffers other than 0 are application specific and not used by the forms library routines. field_buffer() returns the value of field buffer buf.
Every field has an associated status flag that is set whenever the contents of field buffer 0 changes. set_field_status() sets the status flag of field to status. field_status() returns the status of field.
set_max_field() sets a maximum growth on a dynamic field, or if max=0 turns off any maximum growth.
field_buffer() returns NULL on error.
field_status() returns TRUE or FALSE.
set_field_buffer(), set_field_status(), and set_max_field() return one of the following:
Thefunction returned successfully.
System error
An argument is incorrect.
curses(3CURSES), forms(3CURSES), attributes(5)
The header <form.h> automatically includes the headers <eti.h> and <curses.h>.
