| Skip Navigation Links | |
| Exit Print View | |
Understanding Oracle Java CAPS Master Index Configuration Options (Repository) Java CAPS Documentation |
About Oracle Java CAPS Master Index (Repository)
Features of Oracle Java CAPS Master Index
Configuration Overview for Oracle Java CAPS Master Index (Repository)
About the Configuration Files for Oracle Java CAPS Master Index (Repository)
Master Index Object Definition File
Master Index Candidate Select File
Master Index Field Validation File
Master Index Enterprise Data Manager File
Match and Standardization Engine Configuration Files
Using the Editors for Oracle Java CAPS Master Index (Repository)
Configuration Editor - Repository
Master Index Object Definition Configuration (Repository)
Master Index Object Definition Components (Repository)
Master Index Object Definition Objects
Master Index Object Definition Fields
Master Index Object Definition Relationships
The Master Index Object Definition File (Repository)
Modifying the Master Index Object Definition
Object Definition File Description
Object Definition File Example
Candidate Select Configuration (Repository)
Query Builder Components (Repository)
Basic Queries in a Master Index (Repository)
Blocking Queries in a Master Index (Repository)
Phonetic Queries in a Master Index (Repository)
The Candidate Select File (Repository)
Modifying the Candidate Select File
Candidate Select File Description
Range Search Processing (Repository)
Blocking Query Range Searching
Blocking Query Offset and Constant Combinations
Threshold Configuration (Repository)
Manager Service Components (Repository)
The Threshold File (Repository)
Match Field Configuration (Repository)
Matching Service Components (Repository)
Match and Standardization Engines
Block Picker and Pass Controller
Sample Standardization and Matching Sequence (Repository)
The Match Field File (Repository)
Modifying the Match Field File
Best Record Configuration (Repository)
The Survivor Calculator and the SBR (Repository)
Update Manager Components (Repository)
Survivor Helper Default Strategy
Survivor Helper Weighted Strategy
Survivor Helper Union Strategy
Weighted Calculator SourceSystem Strategy
Weighted Calculator SystemAgreement Strategy
Weighted Calculator MostRecentModified Strategy
Update Manager Update Policies
Update Manager Update Policy Flag
The Best Record File (Repository)
Modifying the Best Record File
Field Validation Configuration (Repository)
The Field Validation File (Repository)
Modifying the Field Validation File
Enterprise Data Manager Configuration
The Enterprise Data Manager File Structure
Modifying the Enterprise Data Manager File
Enterprise Data Manager File Description
You can define custom logic for field validations and then specify them in the Field Validation file to associate the logic with the master index application. The custom logic is created as a Java class using the Custom Plug-ins function of the master index project. The custom validation classes must implement com.stc.eindex.objects.validation.ObjectValidator. The exception thrown is com.stc.eindex.objects.validation.exception.ValidationException.
The following topic describes the structure of the Field Validation file and provides information about custom field validators.
By default, the Field Validation file defines one validation rule named validate-local-id. This rule defines certain validations that are performed against local ID and system fields before they are entered into the database. The local ID validator verifies that the system code is valid, the local ID format is correct, the local ID is the correct length, and that neither field is null.
The following topics provide information about working with the the Field Validation file:
You can modify the Field Validation file using the XML editor. The possible modifications to this file are restricted by the schema definition, so be sure to validate the file after making any changes. When you modify this file, you must regenerate the application and redeploy the project for the changes to take effect.
The Field Validation file consists primarily of a list of rules. Each rule is defined within the ValidationConfig element and is defined by attributes within a rules element. Table 13 describes the elements and attributes of the Field Validation file.
Table 13 Field Validation File Elements
Plug the custom validation classes you create into the master index application by specifying the name of the custom plug-in for the class in the Field Validation file, as shown below.
<ValidationConfig module-name="Validation"
parser-class= "com.stc.eindex.configurator.impl.validation.ValidationConfiguration"
<rules>
<rule name="validate-auxiliary-id" object-name="PersonObject"
class="com.stc.eindex.user.AuxiliaryId"/>
<rule name="validate-birth-date" object-name="PersonObject"
class="com.stc.eindex.user.BirthDate"/>
</rules>
</ValidationConfig>
