| Skip Navigation Links | |
| Exit Print View | |
Oracle Java CAPS Master Index Configuration Guide Java CAPS Documentation |
Master Index Configuration Overview
About the Master Index Configuration Files
Modifying the Master Index XML Files Directly
Using the Master Index Master Index Configuration Editor
Match Configuration File (matchConfigFile.cfg)
Maintaining Version Control in the Master Index Configuration Files
Copying, Cutting, and Pasting Files
Configuring the Master Index Object Structure
Adding an Object to the Master Index Object Structure
To Add an Undefined Object (Configuration Editor)
To Add a Predefined Object (Configuration Editor)
To Add an Undefined Object (XML editor)
Modifying an Object's Name In the Master Index Object Definition
To Modify an Object's Name (Configuration Editor)
To Modify an Object's Name (XML Editor)
Deleting an Object From the Master Index Object Structure
To Delete an Object (Configuration Editor)
To Delete an Object (XML Editor)
Adding a Field to the Master Index Object Structure
To Add a Field (Configuration Editor)
Deleting a Field from the Master Index Object Structure
To Delete a Field (Configuration Editor)
To Delete a Field (XML Editor)
Modifying Master Field Properties
To Modify Field Properties (Configuration Editor)
To Modify Field Properties (XML Editor)
Defining Relationships Between Master Index Objects
To Define Object Relationships (XML Editor)
Master Index Field Properties and Name Restrictions
Master Index Field Name Restrictions
Master Index Configuration Editor Field Properties
Master Index Field Property Elements
Creating a Master Index Basic Query
To Create a Basic Query (Configuration Editor)
To Create a Basic Query (XML Editor)
Master Index Query Builder Dialog Box Fields and XML Elements
Creating Master Index Blocking Queries
To Create a Blocking Query (Configuration Editor)
To Create a Blocking Query (XML Editor)
Master Index Query Block Fields and XML Elements
Modifying Master Index Queries
Modifying a Master Index Query
To Modify a Basic Query (Configuration Editor)
To Modify a Query (XML Editor)
Adding a Query Block to a Master Index Query
To Add a Query Block (Configuration Editor)
To Add a Query Block (XML Editor)
Modifying a Query Block for a Master Index Query
To Modify a Query Block (Configuration Editor)
To Modify a Query Block (XML Editor)
Deleting a Query Block From a Master Index Query
To Delete a Query Block (Configuration Editor)
To Delete a Query Block (XML Editor)
To Delete a Query (Configuration Editor)
Configuring Master Index Processing Options
Specifying Master Index Custom Logic Classes
To Specify Custom Logic for External System Messages
To Specify Custom Logic for the Master Index Data Manager
Specifying the Master Index Update Mode
To Specify Potential Duplicates be Reevaluated at Each Update
To Specify Potential Duplicates not be Reevaluated at Each Update
Configuring Master Index Merged Record Updates
To Allow Merged Record Updates
To Prevent Merged Record Updates
Specifying the Master Index Blocking Query for Matching
To Specify the Blocking Query for Matching
Setting Master Index Blocking Query Options
Defining Master Index Transactional Support
To Configure the Master Index for Local Transactions
To Configure the Master Index to Distributed Transactions Across Applications
To Configure the Master Index for Distributed Transactions Within the Master Index Application Only
Configuring Matching Parameters
Specifying the Master Index Decision Maker Class
To Specify the Decision Maker Class
Defining How to Handle Multiple Assumed Matches (OneExactMatch)
To Create Potential Duplicates When Multiple Records Match
To Match the Highest Weighted Records When Multiple Records Match
Specifying Whether Same System Matches are Allowed (SameSystemMatch)
To Allow Same System Records to be Automatically Merged
To Prevent Same System Records From Being Automatically Merged
Specifying the Master Index Duplicate Threshold
To Specify the Duplicate Threshold (Configuration Editor)
To Specify the Duplicate Threshold (XML Editor)
Specifying the Master Index Match Threshold
To Specify the Match Threshold (Configuration Editor)
To Specify the Match Threshold (XML Editor)
Adding and Deleting Master Index Decision Maker Parameters
To Add a New Decision Maker Parameter
To Delete a Decision Maker Parameter
Configuring Master Index EUIDs
Specifying the Master Index EUID Generator Class
To Specify the EUID Generator Class
Specifying the Master Index EUID Length
Specifying a Master Index Checksum Length
Specifying the Master Index Chunk Size
Adding and Deleting Master Index EUID Generator Parameters
To Add EUID Generator Parameters
To Delete EUID Generator Parameters
Defining Master Index Normalization Rules
Defining a Master Index Field to be Normalized
To Define a Field to be Normalized (Configuration Editor)
To Define a Field to be Normalized (XML Editor)
Master Index Normalization and Standardization Structure Properties
Master Index Variants Properties
Modifying a Master Index Normalization Definition
To Modify a Normalization Definition (Configuration Editor)
To Modify a Normalization Structure (XML Editor)
Deleting a Master Index Normalization Definition
To Delete a Normalization Definition
To Delete a Normalization Structure
Defining Master Index Standardization Rules
Defining Master Index Fields to be Standardized
To Define Fields to be Standardized (Configuration Editor)
To Define Fields to be Standardized (XML Editor)
Master Index Standardization Source and Target Field Elements
Modifying a Master Index Standardization Definition
To Modify a Standardization Definition (Configuration Editor)
To Modify a Standardization Definition (XML Editor)
Deleting a Master Index Standardization Definition
To Delete a Standardization Definition (Configuration Editor)
Defining Phonetic Encoding for the Master Index
Defining Master Index Fields for Phonetic Encoding
To Define a Field for Phonetic Encoding (Configuration Editor)
To Define a Field for Phonetic Encoding (XML Editor)
Master Index Phonetic Encoding Fields and Elements
Modifying a Master Index Phonetic Encoding Definition
To Modify a Phonetic Encoding Definition (Configuration Editor)
To Modify a Phonetic Encoding Definition (XML Editor)
Deleting a Master Index Phonetic Encoding Definition
To Delete a Phonetic Encoding Definition (Configuration Editor)
To Delete a Phonetic Encoding Definition (XML Editor)
Defining a Master Index Phonetic Encoder
To Define a Phonetic Encoder (Configuration Editor)
To Define a Phonetic Encoder (XML Editor)
Master Index Encoder Elements and Types
Modifying a Master Index Phonetic Encoder
To Modify a Phonetic Encoder (Configuration Editor)
To Modify a Phonetic Encoder (XML Editor)
Deleting a Master Index Phonetic Encoder
Defining the Master Index Match String
Creating the Master Index Match String
To Create the Match String (Configuration Editor)
To Create the Match String (XML Editor)
Modifying the Master Index Match String
To Modify the Match String (Configuration Editor)
To Modify the Match String (XML Editor)
Defining how Master Index Query Blocks are Processed
To Specify the Pass Controller Class
Defining the Master Index Survivor Calculator
Specifying the Master Index Survivor Helper
To Specify the Survivor Helper
Specifying a Master Index Default Survivor Strategy
To Specify a Default Survivor Strategy
Configuring the Default Survivor Strategy
Master Index Default Survivor Strategy Parameter Elements
Defining the Master Index Single Best Record Structure
Defining a Master Index Survivor Strategy for a Field or Object
To Define a Survivor Strategy for a Field
Defining Master Index Custom Weighted Strategies
Defining Custom Weighted Strategies
Configuring Weighted Strategies
Modifying Weighted Calculator Parameters
Deleting Weighted Calculator Parameters
Master Index Weighted Calculator Parameter Elements
Filtering Default Values From Master Index Processes
To Filter Default Values From the SBR, Blocking Query, or Match Process
Configuring Master Index Update Policies
Defining Master Index Update Policies
Setting the Master Index Update Policy Flag
Defining Custom Field Validations for the Master Index
To Implement a Validation Rule
Specifying a Match Engine for the Master Index
Configuring the Comparison Functions for a Master Index Application
To Configure the Comparison Functions (Configuration Editor)
To Configure the Comparison Functions (Text Editor)
Match Comparator Configuration Properties for Oracle Java CAPS Master Index
Importing Custom Comparison Functions
To Import a Comparison Function
Deleting a Custom Comparison Function
To Delete a Custom Comparison Function
Configuring the Standardization Engine
Specifying a Standardization Engine for the Master Index
To Specify the Standardization Engine
Modifying Master Index Standardization Files
To Modify Standardization Data Configuration Files
Importing Standardization Data Types and Variants
To Import a Data Type or Variant
Deleting a Standardization Variant or Data Type
To Delete a Variant or Data Type
Configuring the Master Index MIDM Appearance
Deleting Objects From the MIDM
MIDM Field Configuration Elements
To Remove a Field From the MIDM
Modifying MIDM Field Display Options
To Modify a Field's Display Options
Specifying a Drop-Down List for an MIDM Field
Specifying an MIDM Field's Length and Format
To Modify a Field's Length and Format
Modifying an MIDM Field's Data Type
Defining Key Fields for an Object
Masking Field Values on the MIDM
To Mask Field Values on the MIDM
Defining MIDM Object Relationships
Configuring the Master Index MIDM Pages
Specifying the Initial View for the MIDM
Configuring the MIDM Duplicate Records Page
Configuring Duplicate Records Display Options
Configuring Duplicate Records Search Pages
Configuring the Duplicate Records Results List
Duplicate Records Page Configuration Elements
Duplicate Records Search Page Elements
Duplicate Records Search Results List Elements
Configuring the MIDM Record Details Page
To Configure Record Details Display Options
Creating Search Pages on the Record Details Page
Step 1: Define the Search Page
Step 2: Define the Search Fields
Step 3: Specify Search Options
Record Details Search Page Definition Elements
Record Details Search Field Definition Elements
Record Details Search Option Elements
Modifying a Search Page on the Record Details Page
Modifying a Search Page Definition
Modifying Record Details Search Page Options
Configuring the MIDM Assumed Matches Page
To Configure the Assumed Matches Page
Configuring the MIDM Transactions Page
To Configure the Transactions Page
Configuring the MIDM Reports Page
Configuring the Reports Page Definition
Configuring Production Reports
Production Reports Definition Elements
Activity Reports Definition Elements
Activity Reports Page Definition Elements
Activity Reports Search Elements
Activity Reports Results Elements
Configuring the MIDM Source Record Page
Configuring the Source Record Page Definition
Configuring the Tabbed Pages on the Source Record Page
Configuring the MIDM Audit Log Page
To Configure the Audit Log Page
Configuring Master Index MIDM Implementation Information
Specifying the Master Controller JNDI Class
To Specify the Master Controller JNDI Class
Specifying the Master Index Report Generator JNDI Class
To Specify the Report Generator JNDI Class
Specifying Master Index Validation Services
To Specify the Validation Service
Setting Master Index Debug Options
Oracle Java CAPS Master Index provides configurable phonetic encoding capabilities. Phonetic encoding is a part of the standardization process, and is the process of changing the value of a data field to its phonetic equivalent. It is used to retrieve records with similar field values from the database for matching. You can specify which fields are phonetically encoded before matching and how they are encoded. There are several different encoders you can use for this purpose. This is most commonly done for first names and street names.
Phonetic encoding is defined in mefa.xml. You can define phonetic encoding by either using the Configuration Editor or modifying the XML file directly. The changes you make on the Phoneticized Field page of the Configuration Editor are reflected in the phonetic encoding structures and the match service section of mefa.xml. The Configuration Editor provides a simplified way of defining phonetic encoding.
Perform any of the following tasks to define phonetic encoding rules:
You can specify the fields you want to be phonetically encoded, the fields that store the encoded values, and the type of phonetic encoder to use for each field, such as NYSIIS or Soundex. A sample phonetic encoding structure for the XML file is included at the end of these instructions.
The Configuration Editor appears.
For more information, see Adding a Field to the Master Index Object Structure.
The Phoneticized Field page appears.
The Phoneticized Field dialog box appears.
The phonetic encoding definition is added to the Phoneticized Fields list.
In object.xml, create the field that will contain the phonetic value. For more information, see Adding a Field to the Master Index Object Structure.
The file opens in the NetBeans XML editor.
Example 4 Phonetic Encoding Structure
<phoneticize-fields>
<phoneticize-field>
<unphoneticized-source-field-name>Person.FirstName
</unphoneticized-source-field-name>
<phoneticized-target-field-name>Person.FirstNamePhoneticCode
</phoneticized-target-field-name>
<encoding-type>Soundex</encoding-type>
</phoneticize-field>
</phoneticize-fields>
The following table lists and describes the Configuration Editor fields and XML file elements used to define how fields will be phonetically encoded.
Once you create a phonetic encoding definition, you can modify it as needed. Use caution when modifying definitions once a system is in production. This can cause inconsistent match results.
Once you create a phonetic encoding definition, you can delete it as needed. Use caution when deleting definitions once a system is in production. This can cause inconsistent match results.
Using the example below, to delete the first name phonetic field, delete the boldface text.
<phoneticize-field>
<unphoneticized-source-field-name>Person.LastName
<phoneticized-target-field-name>Person.LastNamePhoneticCode
<encoding-type>NYSIIS</encoding-type>
<phoneticize-field>
</phoneticize-fields>Each type of phonetic encoder provided with Oracle Java CAPS Master Index is defined in the PhoneticEncodersConfig section of mefa.xml. They are listed in the Encoders section of the Configuration Editor.
The Phonetic Encoder dialog box appears.
Note - For more information about the encoder class paths, see Master Index Encoder Elements and Types.
The phonetic encoder is added to the Encoders list.
The following table lists and describes the elements that configure the phonetic encoders used by the master index application.
The following table lists the phonetic encoders supported by the Master Index Standardization Engine along with the names of their default classes.
Once you define a phonetic encoder, you can change the implementation class to use for the encoder. Use caution when modifying definitions once a system is in production. This can cause inconsistent match results.
Once you define a phonetic encoder, you can delete it if needed. Use caution when deleting encoders once a system is in production. This can cause inconsistent match results. If you delete an encoder that is referenced by a phonetic encoding definition, make sure to modify that definition by referencing an existing encoder.
