| Skip Navigation Links | |
| Exit Print View | |
United States Patient Solution Using MDM Java CAPS Documentation |
Benefits of the United States Solution
United States Patient Solution Template
This topic provides an example on how to create a user called usa. To create a different user, edit the createuser–usa.sql file. For links to instructions on the various tasks when setting up your healthcare solution, see United States Patient Solution Uses.
Before You Begin
The Oracle scripts that come with the solution create a user identified as usa. They are located in the Solutions\NB\MI\project\USAPatient\sca\source\DatabaseScript directory.
Tip - Run the create.sql script first.
create.sql
codelist.sql
systems.sql
createIndexes.sql
createUserCodeData.sql
