| Skip Navigation Links | |
| Exit Print View | |
United States Patient Solution Using MDM Java CAPS Documentation |
Benefits of the United States Solution
United States Patient Solution Uses
To Use the United States Patient Solution
The United States Patient Solution template is located on your installation media under components\addons\MDM\solutions. You can view information about how this solution is configured at http://java.net/downloads/javacaps-samples/Mural/Solutions/Solutions.html.
As the social security number, SSN, is the major United States identifier of healthcare patients, it is included as one of the keys for block-search definitions and matches on the main USAPatient node in the template. The four matching keys for searches are:
FirstName
LastName
Gender
SSN
The SSN is comprised of three sections: nine digits (social security number) that are divided by two hyphens using the format of nnn-nn-nnnn. All nine digits are important, although at times after the SSN has been recorded in the system only the last four digits are used for identity purposes when cross-referenced with other key identifiers.
In the template, only the USAPatient node contains mandatory variables. All the sub-nodes, for example Address and Contact, are optional.
Every effort has been made to make the template specific to the United States healthcare industry.
See Also
