| Skip Navigation Links | |
| Exit Print View | |
Australia Patient Solution Using MDM Java CAPS Documentation |
Benefits of the Australia Patient Solution
Australia Patient Solution Template
This topic provides an example on how to create a user called aus. To create a different user, edit the createuser–aus.sql file. For links to instructions on the various tasks when setting up your healthcare solution, see Australia Patient Solution Uses.
Before You Begin
The Oracle scripts that come with the solution create a user identified as aus. They are located in the Solutions\NB\MI\project\AUSPatient\sca\source\DatabaseScript directory.
Tip - Run the create.sql script first.
create.sql
codelist.sql
systems.sql
createIndexes.sql
createUserCodeData.sql
