| Skip Navigation Links | |
| Exit Print View | |
Australia Patient Solution Using MDM Java CAPS Documentation |
Benefits of the Australia Patient Solution
Australia Patient Solution Uses
To Use the Australian Patient Solution
The Australian Patient Solution template is located on your installation media under components\addons\MDM\solutions. You can view information about how this solution is configured at http://java.net/downloads/javacaps-samples/Mural/Solutions/Solutions.html.
As the medicare card number, MedicareNo, is the major Australian identifier of healthcare patients, it is included as one of the keys for block-search definitions and matches on the main AUSPatient node in the template. The five matching keys for searches are:
FirstName
MiddleName
LastName
Gender
MedicareNo
The MedicareNo is comprised of four sections: eight digits (family identifier) + check digit + card issue number + optional card line number. However, only the first nine digits are important.
In the template, only the AUSPatient node contains mandatory variables. All the sub-nodes, for example Address and Contact, are optional.
Every effort has been made to make the template specific to the Australian healthcare industry.
Note - As the Australian tax file number (TFN) is not used in the healthcare industry, it is not included with the solution template.
