| Skip Navigation Links | |
| Exit Print View | |
United Kingdom Patient Solution Using MDM Java CAPS Documentation |
Benefits of the United Kingdom Patient Solution
United Kingdom Patient Solution Template
This topic provides an example on how to create a user called uk. To create a different user, edit the createuser-uk.sql file. For links to instructions on the various tasks when setting up your healthcare solution, see United Kingdom Patient Solution Uses.
Before You Begin
The Oracle scripts that come with the solution create a user identified as uk. They are located in the Solutions\NB\MI\project\UKPatient\sca\source\DatabaseScript directory.
Tip - Run the create.sql script first.
create.sql
codelist.sql
systems.sql
createIndexes.sql
createUserCodeData.sql
