| Skip Navigation Links | |
| Exit Print View | |
United Kingdom Patient Solution Using MDM Java CAPS Documentation |
Benefits of the United Kingdom Patient Solution
United Kingdom Patient Solution Uses
To Use the United Kingdom Patient Solution
Creating a Database for the United Kingdom Patient Solution
To Create a Database for the United Kingdom Patient Solution
The United Kingdom Patient Solution template is located on your installation media under components\addons\MDM\solutions. You can view information about how this solution is configured at http://java.net/downloads/javacaps-samples/Mural/Solutions/Solutions.html.
The IdNumType and IdNum fields are sometimes used as HealthID identifiers for United Kingdom healthcare patients. If they are used they can be helpful when creating block-search definitions and matches. The IdNumType and IdNum fields are included as two of the keys for matching information on the main UKPatient node in the template. The seven matching keys for searches are:
FamilyName
GivenName
Gender
DOB
DOB is the person's date of birth.
NI
NI is the National Insurance number. It is used for state pension and social security claims. Everyone in the United Kingdom has a National Insurance number.
The National Insurance number must be 9 characters long, and it is broken down as follows:
First 2 characters are alpha but the first character cannot be D, F, I, Q, U, or V, and the second character cannot be D, F, I O, Q, U, or V. Also, the 2 characters cannot pair up as GB, NK, TN, or ZZ.
Characters 3 through 8 are numeric.
Last character can be an A, B, C, D, or a space.
IdNumType
IdNum
In the template, only the UKPatient node contains mandatory variables. All the sub-nodes, for example UKAddress and Consent, are optional.
Every effort has been made to make the template specific to the United Kingdom healthcare industry.
