Table 13.4, “Power LED” lists the actions to take based on the state of the power LED on Sun Ray Clients.
Table 13.4. Power LED
Sun Ray Client Hardware State | Action to Take |
Off | Check to see whether the Sun Ray Client is plugged in. Replace the Sun Ray Client. |
Green | Normal operation. |
Amber | Hardware fault. Replace the Sun Ray Client. |
Blinking | PROM is corrupted. Check that firmware downloads are configured and enabled, then power cycle the Sun Ray Client. |
Card reader LED remains on even when card is removed | Card reader hardware problem. Replace the Sun Ray Client. |
