| Skip Navigation Links | |
| Exit Print View | |
Oracle Solaris Cluster Data Service for Oracle Guide Oracle Solaris Cluster 4.0 |
1. Installing and Configuring HA for Oracle
Planning the HA for Oracle Installation and Configuration
Configuration Planning Questions
How to Configure the Oracle Database Access Using Solaris Volume Manager
How to Configure the Oracle Database Access Using Oracle ASM
How to Configure an Oracle Grid Infrastructure for Clusters SCAN Listener
Installing the Oracle ASM Software
Verifying the Oracle ASM Software Installation
Installing the Oracle Software
How to Install the Oracle Software
How to Set the Oracle Kernel Parameters
Verifying the Oracle Installation and Configuration
How to Verify the Oracle Installation
How to Create a Primary Oracle Database
Setting Up Oracle Database Permissions
How to Set Up Oracle Database Permissions
Installing the HA for Oracle Package
How to Install the HA for Oracle Package
Registering and Configuring HA for Oracle
Tools for Registering and Configuring HA for Oracle
Setting HA for Oracle Extension Properties
How to Register and Configure HA for Oracle (clsetup)
How to Register and Configure HA for Oracle Without Oracle ASM (CLI)
How to Register and Configure HA for Oracle With Clustered Oracle ASM Instance (CLI)
Verifying the HA for Oracle Installation
How to Verify the HA for Oracle Installation
Location of HA for Oracle Log Files
Tuning the HA for Oracle Fault Monitors
Operation of the Oracle Server Fault Monitor
Operation of the Main Fault Monitor
Operation of the Database Client Fault Probe
Operations to Monitor the Partition for Archived Redo Logs
Operations to Determine Whether the Database is Operational
Actions by the Server Fault Monitor in Response to a Database Transaction Failure
Scanning of Logged Alerts by the Server Fault Monitor
Operation of the Oracle Listener Fault Monitor
Obtaining Core Files for Troubleshooting DBMS Timeouts
Customizing the HA for Oracle Server Fault Monitor
Defining Custom Behavior for Errors
Changing the Response to a DBMS Error
Responding to an Error Whose Effects Are Major
Ignoring an Error Whose Effects Are Minor
Changing the Response to Logged Alerts
Changing the Maximum Number of Consecutive Timed-Out Probes
Propagating a Custom Action File to All Nodes in a Cluster
Specifying the Custom Action File That a Server Fault Monitor Should Use
How to Specify the Custom Action File That a Server Fault Monitor Should Use
Changing the Role of an Oracle Data Guard Instance
How to Change the Role of an Oracle Data Guard Instance
A. HA for Oracle Extension Properties
B. Preset Actions for DBMS Errors and Logged Alerts
The following task maps summarize the tasks for installing and configuring HA for Oracle. The tables also provide cross-references to detailed instructions for performing the tasks.
Perform these tasks in the order that they are listed. If you are using HA for Oracle with Oracle Data Guard, perform these tasks on each cluster where your Oracle database instances are running.
Table 1-1 Task Map: Installing and Configuring HA for Oracle
Table 1-2 Task Map: Installing and Configuring HA for Oracle with Clustered Oracle ASM
