Skip Navigation Links | |
Exit Print View | |
man pages section 3: Networking Library Functions Oracle Solaris 11 Information Library |
DNSServiceConstructFullName(3DNS_SD)
DNSServiceCreateConnection(3DNS_SD)
DNSServiceEnumerateDomains(3DNS_SD)
DNSServiceProcessResult(3DNS_SD)
DNSServiceQueryRecord(3DNS_SD)
DNSServiceReconfirmRecord(3DNS_SD)
DNSServiceRefDeallocate(3DNS_SD)
DNSServiceRegisterRecord(3DNS_SD)
DNSServiceRemoveRecord(3DNS_SD)
DNSServiceUpdateRecord(3DNS_SD)
gss_create_empty_oid_set(3GSS)
gss_inquire_cred_by_mech(3GSS)
gss_inquire_mechs_for_name(3GSS)
gss_inquire_names_for_mech(3GSS)
gss_process_context_token(3GSS)
ldap_enable_translation(3LDAP)
ldap_get_entry_controls(3LDAP)
ldap_get_lang_values_len(3LDAP)
ldap_init_getfilter_buf(3LDAP)
ldap_init_searchprefs_buf(3LDAP)
ldap_init_templates_buf(3LDAP)
ldap_parse_extended_result(3LDAP)
ldap_parse_sasl_bind_result(3LDAP)
ldap_sasl_interactive_bind_s(3LDAP)
ldap_set_string_translators(3LDAP)
ldap_translate_from_t61(3LDAP)
rpc_gss_get_principal_name(3NSL)
rpc_gss_svc_max_data_length(3NSL)
sasl_auxprop_add_plugin(3SASL)
sasl_canonuser_add_plugin(3SASL)
sasl_client_plug_init_t(3SASL)
sasl_server_plug_init_t(3SASL)
sasl_server_userdb_checkpass_t(3SASL)
sasl_server_userdb_setpass_t(3SASL)
sdp_add_connection(3COMMPUTIL)
sdp_add_information(3COMMPUTIL)
sdp_delete_all_field(3COMMPUTIL)
sdp_delete_all_media_field(3COMMPUTIL)
sdp_delete_attribute(3COMMPUTIL)
sdp_find_attribute(3COMMPUTIL)
sdp_find_media_rtpmap(3COMMPUTIL)
sdp_session_to_str(3COMMPUTIL)
sip_create_dialog_req_nocontact(3SIP)
sip_delete_header_by_name(3SIP)
sip_disable_dialog_logging(3SIP)
sip_disable_trans_logging(3SIP)
sip_enable_dialog_logging(3SIP)
sip_enable_trans_logging(3SIP)
sip_get_contact_display_name(3SIP)
sip_get_content_sub_type(3SIP)
sip_get_dialog_local_contact_uri(3SIP)
sip_get_dialog_local_cseq(3SIP)
sip_get_dialog_local_tag(3SIP)
sip_get_dialog_local_uri(3SIP)
sip_get_dialog_remote_cseq(3SIP)
sip_get_dialog_remote_tag(3SIP)
sip_get_dialog_remote_target_uri(3SIP)
sip_get_dialog_remote_uri(3SIP)
sip_get_dialog_route_set(3SIP)
sip_get_from_display_name(3SIP)
sip_get_passertedid_display_name(3SIP)
sip_get_passertedid_uri_str(3SIP)
sip_get_ppreferredid_display_name(3SIP)
sip_get_ppreferredid_uri_str(3SIP)
sip_get_proxy_authen_param(3SIP)
sip_get_proxy_authen_scheme(3SIP)
sip_get_proxy_author_param(3SIP)
sip_get_proxy_author_scheme(3SIP)
sip_get_replyto_display_name(3SIP)
sip_get_retry_after_cmts(3SIP)
sip_get_retry_after_time(3SIP)
sip_get_route_display_name(3SIP)
sip_get_via_sent_by_host(3SIP)
sip_get_via_sent_by_port(3SIP)
sip_get_via_sent_protocol_name(3SIP)
sip_get_via_sent_protocol_version(3SIP)
sip_get_via_sent_transport(3SIP)
sip_get_www_authen_param(3SIP)
sip_get_www_authen_scheme(3SIP)
sip_unregister_all_sent_by(3SIP)
- return string representations
cc [ flag ... ] file ... -lsip [ library ... ] #include <sip.h> char *sip_msg_to_str(sip_msg_t sip_msg, int *error);
char *sip_hdr_to_str(sip_header_t sip_header, int *error);
char *sip_reqline_to_str(sip_msg_t sip_msg, int *error);
char *sip_respline_to_str(sip_msg_t sip_msg, int *error);
char *sip_sent_by_to_str(int *error);
The sip_msg_to_str() function returns the string representation of the SIP message sip_msg. Deleted headers are not included in the returned string. The caller is responsible for freeing the returned string.
The sip_hdr_to_str() function returns the string representation of the SIP header sip_header. The caller is responsible for freeing the returned string.
The sip_reqline_to_str() function returns the string representation of the request line from the SIP message sip_msg. The caller is responsible for freeing the returned string.
The sip_respline_to_str() function returns the string representation of the response line from the SIP message sip_msg. The caller is responsible for freeing the returned string.
The sip_sent_by_to_str() function can be used to retrieve the list of sent-by values registered with the stack. The returned string is a comma separated list of sent-by values. The caller is responsible for freeing the returned string.
The sip_msg_to_str(), sip_hdr_to_str(), sip_reqline_to_str(), sip_respline_to_str(), and sip_sent_by_to_str() functions return the relevant string on success and NULL on failure.
The value of errno is not changed by these calls in the event of an error.
For the sip_msg_to_str(), sip_hdr_to_str(), sip_reqline_to_str(), and sip_respline_to_str(), one of the following values is set if the error is non-null:
Input is null.
Memory allocation failure.
On success, the value of the location pointed to by error is set to 0.
