Skip Navigation Links
Exit Print View
Sun Storage Common Array Manager
Software Release Notes, Release 6.9.0 Update
search filter icon
search icon
Document Information
1.  Sun Storage Common Array Manager Software Release Notes
What's New in This Update
How to Get the Software
For Product Information...
What You Get with the Software
Security Advisory
Licensing Optional Premium Features
90-day Evaluation Licenses
System Requirements
Supported Arrays
Supported Web Browsers
Best Practices for Browser Performance
Supported Languages
Patches
Supported Operating Systems
Documentation
Firmware
2500 Arrays Upgrade
2500 Array Support for VMware ESX 4.1 with Firmware 07.35.55.10 and later
6540, 6140, and FLX380 Arrays Upgrade
J4000 Arrays
Sun Blade 6000 Disk Module
Sun Storage F5100 Flash Array Notes
Supported Expansion Modules
Notable Fixes
Known Issues
Array Issues
Create Snapshot fails using CLI
Controller Smart battery replacement procedure
Array loses communication during registration when IPV6 is enabled
Ancient I/O rebooting due to cache block size
AIX host type for 6140 arrays
Battery nears expiration: 06.xx write back cache should not be disabled
Both RAID controllers reboot after 828.5 days--2500/6000 arrays
Communication Loss reported from Windows and Linux when registering JBODs on Oracle Enterprise Linux 6 proxy
Reboots occur due to ancient I/O being aborted in large configurations
Volume error—evShowVol output: Initialization: Not Completed
Configuration Issues
Reregister Auto Service Request for CAM
Auto Service Request advisory note: DTS Listener transfer
Array name remains unchanged after a full array reset
No email notification for critical and above events
Access Configuration: Cascaded J4400 issues
Access Configuration: Sun Storage 6Gb SAS HBA—OS hangs
Access Configuration fails with error: java.util.HashMap cannot be cast to java.util.Properties
Access Configuration: non-zoned SAS2 wide port aggregation FRU Report display—F5100 + 6Gb/sec HBA
Array lock key must be set before configuration files are imported
ComponentInsertEvent not generated for disk drive inserted into J4200
Current Jobs page can take more than five minutes to display
Expander firmware 5.3.73 does not persist a SAS zone group
Replication status incorrect when primary volume fails
Service Advisor: replacing failed SIM with dual path configurations
Volumes not deleting from the Single Page window
Attempt to delete partner replication set on secondary array fails
Documentation Issues
Incorrect sscs add notification description in CLI guide
2500 Series Release Notes: Simplex vs. Duplex Configurations
Disk Locked description is inaccurate in online help
Firmware Update Issues
Firmware upgrade fails with error: FWR_UPGRADE_FAILURE,6 for J4200/J4400 arrays
Firmware upgrade fails on J4400 SATA drives
Firmware upgrade fails when expander and disks are upgraded together
Firmware upgrade not recognized by GUI until agent runs
Sun Blade 6000 firmware upgrade error: No such expander - 50800200006deabf SIGSEGV in Linux libSTORARC.so
Sun Blade 6000 firmware upgrade fails with down-level expander
Sun Blade 6250 and 6270—upgrading network expansion modules fails
Installation and Upgrade Issues
Error occurs when upgrading 2510 controller and drive firmware
Installation fails on SUSE 10.3 32-bit and 64-bit hosts
Premium Feature Issues
Performance Enhancer for 2500-M2
Enabling Try and Buy license using the CLI
Linux Issues
“Require-Stop” not working in SUSE11.1 innserv jexec init.d script
Logging in to CAM on SUSE11 using invalid password
Adding or removing SATA drives requires host boot
Sun Storage J4000 and F5100 Flash arrays—Linux hot plug issues
Solaris Issues
Solaris with Veritas DMP or other host type
Error—”no execute access to opt/SMgr/agent/ notifysmagent.sh”—occurs during system boot-up
UTM LUNs Controlled by “Solaris Traffic Manager” 6000/2500 arrays
Windows Issues
Add License error using the CLI
Support Data does not save using Windows 2008 R2 SP1 Servers
Contacting Support
Documentation
For hardware information, refer to the array's release notes and hardware installation guide.
Online help and man pages are incorporated into the Sun Storage Common Array Manager software.
You can search for documentation at: http://www.oracle.com/technetwork/documentation/disk-device-194280.html
Table 1-5 Sun Storage Common Array Manager Related Documentation
Documents Related To Sun Storage Common Array Manager
Sun Storage Common Array Manager Quick Start Guide
Sun Storage Common Array Manager Installation and Setup Guide
Sun Storage Common Array Manager CLI Guide
Documents Related to Supported Arrays
Sun Storage Common Array Manager Baseline Firmware Reference
Sun Storage F5100 Flash Array Documentation including Release Notes
Sun Storage J4200 Array Documentation including Release Notes
Sun Storage J4400 Array Documentation including Release Notes
Sun Storage J4500 Array Documentation including Release Notes
SAS-1/SAS-2 Compatibility Upgrade Guide
Sun Blade 6000 Disk Module Documentation including Release Notes
Sun Storage 2500-M2 Arrays Documentation including Release Notes
Sun StorageTek 2500 Arrays Getting Started Guide
Sun StorageTek 2500 Arrays Release Notes
Sun StorageTek 2500 Arrays Firmware Upgrade Guide
Sun Storage 6x80 Array Release Notes
Sun Storage 6580/6780 Hardware Installation Guide
Getting Started Guide for Sun Storage 6580/6780 Rack Mounted Arrays
Sun StorageTek MPIO Device Specific Module Installation Guide for Microsoft Windows OS Platform
Sun StorageTek RDAC Failover Driver Installation Guide for Linux OS
Uniform Command-Line Interface User's Guide
