This chapter contains the following topics:
The JD Edwards EnterpriseOne Portal Reference Guide for Oracle WebCenter covers the Oracle WebCenter technology.
The JD Edwards EnterpriseOne Portal Reference Guide for Oracle WebCenter is meant to be used to supplement the use of the Oracle WebCenter Portal with Oracle JD Edwards portlets and WSRP technology. This guide is not meant to be read front to back. Instead, the user should skip to the necessary parts and use them with other guides that more fully detail the various install processes. The necessary supplementary guides include:
JD Edwards EnterpriseOne Server Manager Guide
Installing Oracle Fusion Middleware WebCenter 11g with JD Edwards EnterpriseOne Red Paper
Customers must conform to the supported platforms for the release as detailed in the JD Edwards EnterpriseOne Minimum Technical Requirements. In addition, JD Edwards EnterpriseOne may integrate, interface, or work with other Oracle products. Refer to the following link for cross-reference material in the Program Documentation for Program prerequisites and version cross-reference documents to assure compatibility of various Oracle products:
http://www.oracle.com/corporate/contracts/index.html
Access the Certifications from My Oracle Support (https://support.oracle.com) by searching for this product from the Certifications tab:
Search for product = JD Edwards EnterpriseOne Portal, and Release Number
EnterpriseOne Tools Release 9.1 supports only the WSRP solution on these Portal Servers:
Oracle WebCenter Portal with WebLogic Server
IBM WebSphere Portal with WebSphere Application Server
Depending on the combination of JD Edwards EnterpriseOne Applications and Tools Release levels, the availability of the different portal solutions is depicted in the following table:
| JD Edwards EnterpriseOne Applications Release Level | WSRP (WebCenter 11g and WLS 10.3.x) |
| 9.1 | |
| 9.0 | X |
| 9.1 | X |
X = supported
