This part of the book applies only to Tools Release 9.1 Update 3 and forward.
One View Watchlists represent collections of items that match user-defined criteria. They enable users to define information to which they would like to be alerted. For example, a user might want to be alerted to outstanding tasks that they need to do or thresholds that have been passed. Watchlists provide an easy way for this information to be conveyed to users.
One View Watchlists enable an administrator to secure which users can view, create, and share Watchlists.If there are existing Watchlists to which you have access, you will see the Watchlists menu on the menu bar within JD Edwards EnterpriseOne.
Watchlists are built from JD Edwards EnterpriseOne queries and are therefore, only supported on forms that support query functionality.
This part contains the following chapters:
