EnterpriseOne ADF applications are composed of ADF bounded task flows packaged into ADF Library JAR files. These JAR files are not deployed as web applications and cannot run individually on an ADF Server. Instead, the packaged ADF applications are deployed in an ADF Library and run inside the EnterpriseOne ADF Container (JDEADFContainer), which is a web application that runs bounded task flows in dedicated, dynamic regions. Within the JDEADFContainer, multiple ADF applications launched from an EnterpriseOne menu run simultaneously with only one ADF application visible to the user at any one time.
To launch an ADF application from EnterpriseOne, a Solution Explorer task of type "ADF Application" must first exist that specifies both an EnterpriseOne proxy application name and an ADF task flow id. Optionally, the proxy application version can also be specified on the task. Otherwise, ZJDE0001 is used as the default version. When the Solution Explorer task is launched, the proxy app name, version, jargon code, and ADF task flow id from the task are sent to the JDEADFContainer. If the ADF task flow is found, the ADF application launches inside an available region of the JDEADFContainer web application.
This chapter contains the following topics:
Each EnterpriseOne ADF application should have an accompanying EnterpriseOne "proxy" application for security, version control, and processing options. Oracle's standard is to name both the EnterpriseOne proxy and ADF applications beginning with the letter E, like E01012.
The EnterpriseOne proxy application must have a processing option field to specify a version for every EnterpriseOne application called by the ADF application that has versions. The versions specified in the processing options can then be used when the ADF application executes form service requests in the data control methods.
You use the AIS PO Service to retrieve processing options for EnterpriseOne proxy applications and applications called by the ADF application. The JDEADFContainer will pass the proxy application's name and version to the ADF application as input parameters, which are stored as Page Flow Scope variables. The below example first retrieves processing options for the proxy application and then retrieves processing options for Address Book based on the P01012 version specified for the proxy application.
Example 7-1 Calling AIS Processing Option Service
if (AISClientCapability.isCapabilityAvailable(loginEnv, AISClientCapability.PROCESSING_OPTION))
try
String appName = (String) ADFContext.getCurrent().getPageFlowScope().get("appName");
if ((appName == null) || (appName.length() == 0))
appName = "E01012";
String appVersion = (String) ADFContext.getCurrent().getPageFlowScope().get("appVersion");
if ((appVersion == null) || (appVersion.length() == 0))
appVersion = "ZJDE0001";
ProcessingOptionRequest e01012PORequest = new ProcessingOptionRequest(loginEnv);
e01012PORequest.setApplicationName(appName);
e01012PORequest.setVersion(appVersion);
String response = JDERestServiceProvider.jdeRestServiceCall(loginEnv, e01012PORequest,
JDERestServiceProvider.POST_METHOD,
JDERestServiceProvider.PO_SERVICE);
ProcessingOptionsSet e01012POSet = loginEnv.getObjectMapper().readValue(response, ProcessingOptionsSet.class);
if (e01012POSet != null)
p01012Version = (String) e01012POSet.getOptionValue("szP01012Version_2");
if ((p01012Version == null) || (p01012Version != null && p01012Version.length() == 0))
p01012Version = "ZJDE0001";
ProcessingOptionRequest p01012PORequest = new ProcessingOptionRequest(loginEnv);
p01012PORequest.setApplicationName("P01012");
p01012PORequest.setVersion(p01012Version);
String response1 = JDERestServiceProvider.jdeRestServiceCall(loginEnv, p01012PORequest,
ProcessingOptionsSet p01012POSet = loginEnv.getObjectMapper().readValue(response1, ProcessingOptionsSet.class);
if (p01012POSet != null)
hideTax = (String) p01012POSet.getOptionValue("HideTax_4");
displaySupplierMaster = (String) p01012POSet.getOptionValue("GoToSupplierMaster_5");
displayCustomerMaster = (String) p01012POSet.getOptionValue("GoToCustomerMaster_6");
searchTypeDefault = (String) p01012POSet.getOptionValue("SearchTypeDefault_7");
displayCSMS = (String) p01012POSet.getOptionValue("GoToCSMS_8");
p0100041Version = (String) p01012POSet.getOptionValue("Version_9");
selfServiceMode = (String) p01012POSet.getOptionValue("cSelfServiceMode_10");
typeCode = (String) p01012POSet.getOptionValue("cTypeCode_11");
postalCodeValidate = (String) p01012POSet.getOptionValue("cPostalCodeValidate_12");
postalAddressRetrieval = (String) p01012POSet.getOptionValue("cPostalAddressRetrieval_13");
p03013Version = (String) p01012POSet.getOptionValue("szCustMasterVersion_VER_14");
p04012Version = (String) p01012POSet.getOptionValue("szSuppMasterVersion_VER_15");
catch (CapabilityException e)
processErrorException(e);
catch (JDERestServiceException e)
processErrorException(JDERestServiceProvider.handleServiceException(e));
catch (Exception e)
else
// Processing Option cability is not supported on AIS. Use default search type.
searchTypeDefault = "E";
As shown in the above example, you retrieve a processing option value from the ProcessingOptionSet object using an identifier. This identifier can be found in the data structure generated for the Processing Option Template in the Object Management Workbench. You use this data structure to find the identifier for each processing option value you need for your ADF application.
Example 7-2 Generated Data Structure for Processing Option Template
* TYPEDEF for Data Structure
* T01012 : Address Book - New Processing Option
* Copyright Oracle USA
* This is a JDEdwards EnterpriseOne generated file.
* Do not modify this file.
* Only re-generate with the appropriate tool.
* Generation Date : 7/9/2015
#ifndef DATASTRUCTURE_T01012
#define DATASTRUCTURE_T01012
typedef struct tagDST01012
JCHAR HideTax;
JCHAR GoToSupplierMaster;
JCHAR GoToCustomerMaster;
JCHAR SearchTypeDefault[4];
JCHAR GoToCSMS;
JCHAR Version[11];
JCHAR cSelfServiceMode;
JCHAR cTypeCode;
JCHAR cPostalCodeValidate;
JCHAR cPostalAddressRetrieval;
JCHAR szCustMasterVersion_VER[11];
JCHAR szSuppMasterVersion_VER[11];
} DST01012 , *LPDST01012;
#define IDERRHideTax_4 4L
#define IDERRGoToSupplierMaster_5 5L
#define IDERRGoToCustomerMaster_6 6L
#define IDERRSearchTypeDefault_7 7L
#define IDERRGoToCSMS_8 8L
#define IDERRVersion_9 9L
#define IDERRcSelfServiceMode_10 10L
#define IDERRcTypeCode_11 11L
#define IDERRcPostalCodeValidate_12 12L
#define IDERRcPostalAddressRetrieval_13 13L
#define IDERRszCustMasterVersion_VER_14 14L
#define IDERRszSuppMasterVersion_VER_15 15L
#endif /* DATASTRUCTURE_T01012 */
E1ADFUtils is a helper class included in the E1UserSession.jar that provides several static methods for accessing functionality available through the JDEADFContainer, including launching an EnterpriseOne menu task, launching an EnterpriseOne application, and displaying error and warning messages using the JDEADFContainer's message popup dialog.
These features are only available when the EnterpriseOne ADF application launches from an EnterpriseOne Solution Explorer task and executes in the JDEADFContainer web application. If the EnterpriseOne ADF application is run on JDeveloper's Integrated WLS, the application code to utilize these features will execute without error, but the JDEADFContainer is not available to provide the desired functionality.| Return Type | Method | Description |
| void | launchE1Task(String taskId) | Launches the EnterpriseOne object associated with the specified task id. |
| void | launchE1Application(E1FormInterconnect formInterconnect) | Launches the specified EnterpriseOne application. |
| void | addErrorMessages(List<E1Message> messages) | Adds a list of E1Message objects to the JDEADFContainer's error message list. |
| void | addErrorMessage(String message) | Adds a single message to the JDEADFContainer's error message list. |
| void | addWarningMessages(List<E1Message> messages) | Adds a list of E1Message objects to the JDEADFContainer's warning message list. |
| void | addWarningMessage(String message) | Adds a single message to the JDEADFContainer's warning message list. |
| void | addInformationMessages(List<E1Message> messages) | Adds a list of E1Message objects to the JDEADFContainer's information message list. |
| void | addInformationMessage(String message) | Adds a single message to the JDEADFContainer's information message list. |
| void | launchMessagePopup() | Displays the JDEADFContainer's message popup dialog. Once the dialog is displayed, the message lists are cleared. |
| void | initializeAppInstance(String path) | Retrieves values from the About.properties file for the ADF application to display in the About dialog. |
To launch an EnterpriseOne menu task from your ADF application, you only need to specify the task id when calling the launchE1Task() method.
To launch an EnterpriseOne application from your ADF application, you need to first create an E1FormInterconnect object to identify the application and form to run and the form interconnect values to pass to the EnterpriseOne application form. Then you call the launchE1Application() method, passing the E1FormInterconnect object as the sole parameter.
Example 7-4 Launching and EnterpriseOne Application
// Launch Address Book Work With Addresses form.
E1FormInterconnect form = new E1FormInterconnect();
form.setApplication("P01012");
form.setForm("W01012B");
form.setVersion("ZJDE0001");
form.addFormInterconnectValue("1", "7500");
form.addFormInterconnectValue("2", "E");
E1AdfUtils.launchE1Application(form);
When a form service request executes on the JAS server, any errors and warnings displayed on the EnterpriseOne form are returned to the ADF application in the JSON response. You can retrieve these messages from the response object and display them to the user using the JDEADFContainer's message popup, which provides a modal dialog window for error, warning, and information messages. You will typically perform the following steps to display messages to the user:
To display a single message, call the E1AdfUtils method to add the individual message to one of the JDEADFContainer's exception lists.
To display multiple messages, collect error, warning, and information messages in separate lists and call the E1AdfUtils methods to add these lists to the JDEADFContainer's exception lists.
Call the launchMessagePopup() method to display the JDEADFContainer's message popup.
Example 7-5 Display a Single Error Message
if (AISClientCapability.isCapabilityAvailable(loginEnv, AISClientCapability.GRID))
// Code to perform Form Service Request and process response.
else
E1AdfUtils.addErrorMessage("The grid capability is not supported on AIS Server.");
E1AdfUtils.launchMessagePopup();
Example 7-6 Display Multiple Error Messages
FormRequest formRequest = new FormRequest(loginEnv);
// Populate form request.
...condensed...
// Execute form request to add new employee to Employee Master using P060116Q.
String response = JDERestServiceProvider.jdeRestServiceCall(loginEnv, formRequest,
JDERestServiceProvider.FORM_SERVICE_URI);
P060116Q_W060116QA_FormParent p060116FormParent = loginEnv.getObjectMapper().readValue(response, P060116Q_W060116QA_FormParent.class);
if (p060116FormParent != null)
// If insert was successful, clear input fields. Otherwise, display errors.
FormErrorWarning[] errors = p060116FormParent.getFs_P060116Q_W060116QA().getErrors();
List<E1Message> errorList = new ArrayList<E1Message>();
if (errors.length > 0)
for (int i = 0; i < errors.length; i++)
errorList.add(new E1Message(E1Message.Severity.ERROR, errors[i].getMOBILE()));
E1AdfUtils.addErrorMessages(errorList);
else
clearInputFields();
As mentioned previously, the JDEADFContainer's message popup will only display when the ADF application is running inside the container. In order to display messages when the application is running on JDeveloper's Integrated WLS, you can conditionalize your error reporting code to use the Java Server Faces messaging feature, as shown in the below example:
Example 7-7 Display Error Messages When Running Locally on JDeveloper's Integrated WLS
else
String msg = "The grid capability is not supported on AIS Server";
if (runningInJDEADFContainer)
E1AdfUtils.addErrorMessage(msg);
else
FacesContext.getCurrentInstance().addMessage("E1ADFApp", new FacesMessage(FacesMessage.SEVERITY_ERROR, "AIS Capability Not Supported ", msg));
See Section 4.1, "Creating a Connection to AIS Server" to review the code that first determines whether the ADF application is running locally or in the JDEADFContainer and then sets the runningInJDEADFContainer boolean accordingly.
The EnterpriseOne container provides an About button that enables you to display information about the ADF application launched within the container. When you click the About button, a dialog box, like the example below, appears and displays similar information:
The dialog box has two sets of information: Application Information, and Task Information. The Application Information is provided by the individual ADF Bounded Task flow.
To setup About Information
Create a new file in your project named about.properties and include the following content:
[About]
applicationName=JD Edwards EnterpriseOne Address Book Reference Application
version=1.0.0
appID=E01012
Make sure to place the file in a package that is named uniquely. The standard location would be with the application named package. In this example it is in the com.oracle.e1.E01012 package.
During the initialization of your application you must communicate to the container where the about.properties for your application is stored. Make sure you have a handshakeId before calling the E1AdfUtils.initializeAppInstance() method. Having a handshakeId is an indication that your application is running within the container.
Pass the package path to your about.properties file as in this example:
The example application shown above is named E01012. "E" is the naming convention Oracle recommends you use for your ADF applications.E1AdfUtils.intializeAppInstance("/com/oracle/e1/E01012/");
