9 Next Steps
After you have installed the JD Edwards EnterpriseOne IBM i Server, you may wish to perform some of these tasks:
Basic security has been set up in the Security tables on the Database Server. The Security Server is running on the Enterprise Server. You must turn on the Security Server on the Deployment Server before running an Oracle Business Accelerator.
The above tasks are described in detail in the JD Edwards EnterpriseOne Applications Release 9.0 Installation Guide for iSeries, which is available in this document on My Oracle Support:
JD Edwards EnterpriseOne Applications Release 9.0 Installation Guides, Update (Doc ID 705463.1)
https://support.oracle.com/CSP/ui/flash.html#tab=KBHome(page=KBHome&id=()),(page=KBNavigator&id=(bmDocID=705463.1&from=BOOKMARK&bmDocDsrc=KB&viewingMode=1143))
Important:
The Support Assistant is delivered with the Deployment Server installation and is located inside the Change Assistant folder. This is an executable that collects information such as configuration and logs. In the event that you place a Service call, Global Customer Service may request that you run the Support Assistant.
For tips on tuning your system, refer to the IBM Redbook entitled IBM System i Performance and Tuning Tips for Oracle's JD Edwards EnterpriseOne 8.12, WebSphere 6.0, and WebSphere 6.1 (Document ID WP100985).
Download this Redbook from an IBM searchable website. Although the document was written for WebSphere and HTTP, it has numerous tips for tuning your entire IBM i system. Examples of tip topics include:
  • QSQSRVR jobs
  • SQLPKGs
  • Index tuning
Further, you can consider those WebSphere 6.1 tuning tips that are applicable to WebSphere 7.
