To test the JD Edwards HTML Web Server connection:
Start a web browser such as Firefox or Internet Explorer.
Enter this URL:
http://<ibm_i_hostname>:80/jde/owhtml
where <ibm_i_hostname> is the name of the JD Edwards HTML Web Server installed by the IBM i Express Installation. For a list of delivered URLs, refer to the section of this guide entitled: Section 4.13, "Understanding the IBM i HTTP, HTML, and Server Manager Agent Components Installation".
Network connectivity is required between the PC or workstation where the web browser is opened and the HTML Web Server before entering the URL.The login screen for JD Edwards EnterpriseOne should appear. The default user ID is JDE, with password JDE. By default, the only environment available is JPD900.
