This chapter contains the following topics:
Section 5.1, "Starting and Shutting Down Network Services on the Enterprise Server"
Section 5.2, "Verifying the Release 9.0 Enterprise Server Installation Using PORTTEST"
The network services are started when you do the following steps:
Log on to the Enterprise Server as ONEWORLD.
Select the E900SYS version and type:
GO A98OWMNU
Start services by selecting option 5.
You can end services by selecting option 6 on this menu.
To verify the Enterprise Server installation using PORTTEST:
GO A98OWMNU
Start PORTTEST by selecting option 4 and type in the following arguments.
Enter this command for each environment, for example:
This program initializes a user and an environment (assuming Release 9.0 is installed and configured correctly). The program displays messages that indicate the selection of records from a Release 9.0 table. If it does not, review the jde_xxxxxx.log file in the IFS directory path /JDE900.
If PORTTEST fails to run, for diagnostic assistance refer to the chapter entitled: Using the PORTTEST Checklist in the JD Edwards EnterpriseOne Applications Release 9.0 Installation Guide for iSeries.
