26 Understanding Data Source Charts
This chapter discusses these data sources:
26.1 Business Data
This chart lists the characteristics of the Business Data data source.
Field Valid Value for Client Access
Data Source Name (list includes possible sources) Business Data - PROD
Business Data - CRP
Business Data - TEST
Business Data - PS910
Data Source Use DB
Data Source Type I
Object Owner ID Blank
Library Name (list includes possible libraries) PRODDTA
TESTDTA
CRPDTA
PS910DTA
Library List Name RDB name of the IBM i
Note: To find the IBM i RDB name, use the WRKRDBDIRE command.
Database Name (list includes possible databases) Business Data - PROD
Business Data - CRPDTA
Server Name Name of the machine where your database resides
Platform IBM i
Use Table Owner Blank
Use Julian Dates Selected
Use Decimal Shift Selected
Support for Updates Selected
OCM Data Source Blank
LOB Data Source Selected
IBM i BLOB Support Blank
26.2 Central Objects
This chart lists the characteristics of the Central Objects data source.
Field Client Access
Data Source Name (list includes possible sources) Central Objects - PY910 (for CRP)
Central Objects - PS910 (for Prist)
Central Objects - PD910 (for Prod)
Central Objects - DV910 (for Dev)
Data Source Use DB
Data Source Type I
Library Name (list includes possible libraries) COPD910 (for Prod)
COPY910 (for CRP)
COPS910 (for Prist)
CODV910 (for Dev)
Database Name (list includes possible databases) Central Objects - PY910
Platform IBM i
26.3 Control Tables
This chart lists the characteristics of the Control Tables data source.
Field Client Access
Data Source Name (list includes possible sources) Control Tables - Prod
Control Tables - CRP
Control Tables - PS910
Control Tables - Test
Data Source Use DB
Data Source Type I
Library Name (list includes possible libraries) PRODCTL
CRPCTL
PS910CTL
TESTCTL
Database Name (list includes possible databases) Control Tables - Prod
Platform IBM i
26.4 Data Dictionary
This chart lists the characteristics of the Data Dictionary data source.
Field Client Access
Data Source Name Data Dictionary - 910
Data Source Use DB
Data Source Type I
Library Name DD910
Database Name Data Dictionary - 910
Platform IBM i
26.5 Logic
This chart lists the characteristics of the Logic data source.
Field Client Access
Data Source Name Name of the machine where your database resides
Data Source Use SVR
Data Source Type I
Library Name xMAP (where x is the release to which you are installing, such as 910)
Note: Ensure the system value for QCCSID is 37.
Database Name machinename - 910 Server Map
Platform IBM i
IBM i BLOB Support Selected
26.6 Object Librarian
This chart lists the characteristics of the Object Librarian data source.
Data Source Name Object Librarian - 910
Data Source Use DB
Data Source Type I
Library Name OL910
Database Name Object Librarian - 910
Platform IBM i
26.7 Language
This chart lists the characteristics of the Language data source, which applies to the Oracle tablespace on the Deployment Server.
Field Valid Value for Oracle
Data Source Name (list includes possible sources) Language
Language – 910
For example, French – 910.
Data Source Use DB
Data Source Type N
Object Owner ID (list includes possible owner IDs) Blank
Library Name Blank
Library List Name Blank
Database Name (list includes possible databases) Language
JDELanguage_F910
Server Name Local
Platform LOCAL
Use Julian Dates Blank
Use Decimal Shift Blank
Support for Updates Blank
26.8 Local
This chart lists the characteristics of the Local data source, which applies to the Oracle tablespace on the Deployment Server.
Data Source Name (list includes possible sources) Local
JDELocal - DV910
JDELocal - PS910
JDELocal - PD910
JDELocal - PY910
Data Source Use DB
Data Source Type N
Object Owner ID (list includes possible owner IDs) dbo
Library Name Blank
Database Name (list includes possible databases) JDELocal
JDEPlan910
JDECTL910
JDEDD910
JDESY910
JDEVL910
JDEOL910
JDEData910
Server Name Local
Platform LOCAL
Use Table Owner Selected
LOB Data Source Blank
26.9 OWJRNL
This chart lists the characteristics of the Journal data source.
Data Source Name (list includes possible sources) OWJRNL
Data Source Use DB
Data Source Type I
Library Name OWJRNL
Database Name OWJRNL
Platform IBM i
26.10 Server Map
This chart lists the characteristics of the Server Map data source.
Data Source Name machinename - 910 Server Map
Data Source Use DB
Data Source Type I
Library Name SVM910
Platform IBM i
OCM Data Source Selected
26.11 System
This chart lists the characteristics of the System data source.
Data Source Name (list includes possible sources) System - 910
Data Source Use DB
Data Source Type I
Library Name SY910
DLL Name Blank
Database Name (list includes possible databases) System - 910
Platform IBM i
26.12 Versions
This chart lists the characteristics of the Versions data source.
Data Source Name (list includes possible sources) Versions - PD910
Versions - PY910
Versions - DV910
Versions - PS910
Data Source Use DB
Data Source Type I
COPY910
CODV910
COPS910
DLL Name Blank
Database Name (list includes possible databases) Versions - PD910
Versions - PY910
Versions - DV910
Versions - PS910
Platform IBM i
