7 Uninstalling the Transaction Server RTE Software Component using Server Manager
Use this procedure to uninstall the Transaction Server RTE Software Component using Server Manager.
  1. Log on to the Server Manager console.
  2. Click on the managed home location.
  3. Select the Transaction Server Real Time Events (RTE) instance.
  4. Click the Remove Instance button.
    This image is described in surrounding text.
