Go to main content
1/18
Contents
Title and Copyright Information
Preface
Documentation Accessibility
Related Documents
Conventions
1
Understanding the Transaction Server Components
1.1
Overview
1.2
Certifications (Formerly Known as Minimum Technical Requirements)
1.3
Obtaining the Transaction Server Managed Software Component
1.4
Prerequisites
1.5
Understanding Transaction Server Communications
2
Configuring the Transaction Server Components
2.1
JDBj Database Configuration
2.1.1
JDBj Bootstrap Datasource
2.1.2
JDBj Bootstrap Session
2.1.3
JDBj Connection Pools
2.1.4
JDBC Drivers
2.1.5
JDBj Logging
2.1.6
Oracle Database Settings
2.1.7
JDBj Runtime Properties
2.1.8
JDBj Spec Datasource
2.2
Real Time Events
2.2.1
Event Processor Configuration Settings
2.2.2
Trigger Listener Kernel
2.3
Network Settings
2.3.1
JDENET Configuration
2.3.2
Security Server Configuration
2.4
Log File Configuration (jdelog.properties)
3
Configuring JD Edwards EnterpriseOne
3.1
Verifying User Defined Codes (UDCs)
3.2
Verifying Tables
3.3
Verifying Serialized Objects
3.4
Activating Events
3.5
Creating Triggers
4
Adding a Subscriber
4.1
Setting Processing Options for Event Subscribers Application (P90702A)
4.2
Using Event Subscribers Application to Add a Subscriber
4.3
Working with Subscribers in JD Edwards EnterpriseOne
4.3.1
Adding a JAVACONN Subscriber
4.3.2
Creating a JMSQUEUE Subscriber
4.3.3
Creating a JMSTOPIC Subscriber
4.3.4
Creating a Subscription
4.3.5
Adding an Event to the Subscription
4.3.6
Adding Environment(s) to a Subscription
5
Troubleshooting Real Time Events Processing
6
Upgrading the Transaction Server RTE Software Component Using Server Manager
7
Uninstalling the Transaction Server RTE Software Component using Server Manager
A
Architecture of the Guaranteed Event System
B
Creating and Configuring Multiple Transaction Servers per Environment or User/Role
B.1
B.2
Creating and Configuring Multiple Transaction Servers per Role/User
C
Working with JMS Topic or JMS Queue
C.1
Use Case for JMS Topic
C.2
Use Case for JMS Queue
D
Testing and Validating the JMSQUEUE Configuration
E
Creating a JMS Topic in the JD Edwards EnterpriseOne Transaction Server Application
F
Creating a Subscriber JMS Queue in WebLogic Server other than Transaction Server
F.1
Creating the JMS Server
F.2
Creating the JMS Module
F.3
Creating the JMS Resource
G
Creating an Oracle JD Edwards EnterpriseOne Service Request for Transaction Server Support
H
Clustering for the JD Edwards Transaction Server on WebLogic Server
H.1
Understanding WebLogic Clustering
H.2
Creating a Cluster on WebLogic Server
H.3
Creating the Servers
H.4
Creating Machines
H.5
Associate Machines with Servers
H.6
Cluster the Servers
H.7
Setup the Cluster for Load Balancing
H.8
Setup the Cluster for Failover
H.9
Installing the Transaction Server RTE Component on WebLogic Server using Server Manager
H.10
Using JDBC Persistent Stores
H.11
Create JDBC Datasources
H.12
Create JDBC Persistent Stores
H.13
Associate a JMS Server with a Persistent Store
H.14
Additional Configuration for Using Horizontal Cluster
Scripting on this page enhances content navigation, but does not change the content in any way.
